Old 05-12-2006, 06:22 PM   #1
R.J.Barnett
R.J.Barnett is on a distinguished road
R.J.Barnett's Avatar
Question Engine Misses. Need Suggestions
My son's '92 SL2 (with 200,000 miles) has a bad miss and severe loss of power. I have replaced the plugs and it has a new catalytic converter. I am looking for the "low hanging fruit" (i.e. easy / cheap) things to try as a "fix". The "Check Engine" light is not on.
I have not (yet) done a compression check. What suggestions would you have for things to check that could likely contribute to this problem?
R.J.Barnett is offline   Reply With Quote
Old 05-12-2006, 06:40 PM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: Engine Misses. Need Suggestions
Did you replace the plug wires? Or try cleaning the throttle body and EGR?
Aut viam inveniam aut faciam
Old 05-12-2006, 06:53 PM   #3
R.J.Barnett
I have not replaced the plug wires, but they appear to be fine and aren't that old (less than 25,000 miles). I have not cleaned the throttle body or the EGR.
Old 05-12-2006, 07:11 PM   #4
R.J.Barnett
I've been doing some more diagnosing and think I have a lead. Examining the plugs that I took out, it appears as though the missfiring is in cylinders "1" and "4". It may be a coincidence, but both of these plugs are fired from the same coil.
Old 05-12-2006, 07:16 PM   #5
Uzzy
Uzzy's Avatar
2002 SC1
Swap coil packs, and see what you find then.
Need Techie Help - Engine Misses/Surges? R.J.Barnett S-Series Tech 9 05-24-2006 11:19 AM
Engine Misses HazManRon S-Series Tech 3 04-06-2005 03:09 PM
Cold engine fine, warm engine misses ?? Scyan S-Series Tech 9 11-05-2002 12:08 AM
Engine misses above 2200 rpm... sl2NewBee S-Series Tech 17 06-09-2002 02:12 PM
Engine misses; service light on UncleMarv S-Series Tech 3 03-19-2000 12:24 AM
