#1 |
![]() Join Date: Aug 2005
My 93 SL2 (208,000 miles) has been missing recently, and it seems it is due to the coil posts. I changed my plug wires recently and noticed one of the posts in particular had a good deal of white substance on it, kind of fuzzy. Any suggestions on cleaning them properly? Also does dialectic grease help with the actual connection with the plug wires, or does it just reduce corrosion?
#2 |
![]() Join Date: Jul 2005
Did they growl at you? >_>
Use a wire brush to scrap the fuzz off. I wouldn't really bother coating them with anything.
Madness takes it's toll: Please have exact change. SES light + unplugged sensor = testicle ownage. |
#3 |
![]() Join Date: May 2002
Actually, I've used 0000 emery cloth; it's a very fine sandpaper, for want of a better word to use... One can pick up a sheet at any hardware store.
> 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired |
#4 |
Wire brush, fine sand paper, steel wool, whatever will get it off. I do use dielectric grease on mine though.
There is nothing more frightening than ignorance in action. |
#5 |
i believe dielectric grease only prevents corrosion, but does nothing in terms of improving conductance ...so a thin layer is good.
#6 |
My 97 SL had the same whitish coating on one of my terminals. I gently sanded it off with fine paper then coated it with d. grease. Working great for over 21K so far! Car starts so quickly, I nearly don't have to turn the key!
![]() Jerry |
#7 |
![]() Join Date: Jan 2005
All good suggestions. I use ScotchBrite. You can get it at most auto parts stores. Also the dielectric grease is to help keep moisture out and thus reduce the chances of corrosion so I use it on my plugs and coils.
One other thing you may want to check is the mount surface of the coil packs. Take the two bolts out that hold them down and clean the surfaces of the bell housing and the bottom the coils and use a bit of the dielectric grease, just a small thin film, there also. |
#8 |
![]() Join Date: Sep 2002
Yesterday my dealer told me that my ignition coil was corroded and suggested replacing them. After reading about cleaning the posts I was wondering if there is a point of no return when it comes to cleaning the posts? Is it possible for there to be too much corroision present? My car is a 99sl2 with 118k miles on it and I live in the northeast where we get moderate amount of snow and the roades are salted. I have never done anything with the coils except change the spark plug wires.
#9 |
I'd say that when the post rots through and falls off, it might have outlived it's useful life, but if you can clean it up, I don't see any reason for it not to work.
#10 |
Yeah i doubt they are about to fall off. I'll try cleaning the posts first with a wire brush. This may be a stupud question but do i need to disconnect my battery to clean the posts?
#11 |
![]() Join Date: May 2005
2000 SL2
Safer, but not necessary, unless you have your ignition on. I've always disconnected the battery when I work on any electronic items-just in case.
Experience is something you don't get until just after you need it. |
#12 | |
![]() Quote:
Ultimately, I would continue to clean the corrosion from both the posts and the base as long as it works. But eventually you will have to replace the coil packs. |
Bookmarks |
cleaning under coil packs | briansc1 | S-Series Tech | 12 | 09-12-2008 07:06 PM |
cleaning coil pack what's the best way | mytimeflies | S-Series General | 9 | 10-02-2007 11:39 PM |
cleaning coil packs question | thawk | S-Series Tech | 2 | 06-29-2006 07:29 AM |
Coil pack cleaning | poorboy | S-Series Tech | 4 | 02-17-2005 03:16 PM |
cleaning coil packs | elewpier5 | S-Series Tech | 4 | 06-10-2004 06:48 PM |
