Old 08-08-2004, 09:17 PM   #1
bobwill
bobwill is on a distinguished road
bobwill's Avatar
2003 ION-1 Sedan
Default Well, first blown turn signal
Well, my passenger side turn signal/drl finally blew while I was on a trip yesterday. Considering that's the factory bulb and it had a year and a half on it I'm not too concerned about it, and I think I'll just go to Advance before work (evening shift) and get a new bulb. However, it is that ominous passanger side bulb, so you think that I should call the dealer?
Bob
bobwill is offline
Old 08-08-2004, 09:30 PM   #2
mrwag
mrwag is on a distinguished road
Default
Our 03 ION3 blew the driver side turn lamp/DRL. Ended up having the whole socket replaced. I replaced the bulb and it worked for like 1 minute and then crapped out again. That's when I called the dealer and had it replaced. No biggie.
mrwag is offline
Old 08-08-2004, 11:30 PM   #3
Johnny No
Johnny No is on a distinguished road
Johnny No's Avatar
Default
My driver's side blinker/DRL can't seem to make up its mind. It's been off and on for the past week or so. Is there some kind of short that could be causing this? The car's only 5 months old so I was kind of surprised. I might wait until I go in for my next oil change to have them look at it. I don't feel like making an appointment and driving 50 miles round trip just for that.
Johnny No is offline
Old 08-09-2004, 10:27 AM   #4
mrwag
Default
The heat from the lamp burned it up, so they said.
mrwag is offline
Old 08-09-2004, 10:38 AM   #5
Kohnen
Kohnen is on a distinguished road
Default
I'd suggest that you look for the 3157 NA LL
That bulb has a 4,000 hour life time for the DRL filament - most of the other bulbs that will fit (e. g., the 3457) only have about 500 hour life time.
Sylvania makes the bulb. It's especially designed for DRL applications.
I've posted another thread regarding this bulb if you want to read ad nauseum about it.
Kohnen is offline
Old 08-09-2004, 10:48 AM   #6
saturnd00d
saturnd00d will become famous soon enough
saturnd00d's Avatar
2008 VUE 2.4L
Default
The Eurolite bulbs I installed in my ION is a 3157. Works like a charm. Maybe all these bulbs are blowing because the bulbs are 3457 equivalent, which are all higher wattage, and the wiring cannot handle that load with stability. Either try going to the dealership for the fix, or try switching your bulbs to 3157 bulbs.
___________________________________
http://www.cardomain.com/id/saturnd00d
saturnd00d is offline
Old 08-09-2004, 04:31 PM   #7
jinjimbob
jinjimbob is on a distinguished road
2004
Default
They replaced the wiring and socket in our Ion.
jinjimbob is offline
Old 08-09-2004, 11:38 PM   #8
ION DEN
ION DEN is on a distinguished road
Default
There is a problem with the front signal bulbs. We have been replacing the bulb, wiring harness and installing resistors to the earlier model Ions. Most Ions built within the past few months have had the resistors installed at the factory. However, if you are out of your 36/36 warranty, look to spend about $110. for the factory replacement wiring.
ION DEN is offline
Turn Signal richamer1 Ion General 5 08-11-2008 10:48 AM
Turn Signal Bogel S-Series Tech 6 04-08-2008 08:27 PM
99 SC turn signal sat96 S-Series General 2 01-31-2005 01:13 PM
Turn signal out? preduck Ion General 26 07-20-2003 03:28 PM
turn signal? 4everis2morrow Ion General 4 07-16-2003 02:14 AM
