Closed Thread
Old 02-19-2000, 12:20 PM   #1
DHOOP
DHOOP is on a distinguished road
Default timing chain
I probably missed this info in the message board changeover but was there ever a reply regarding the use of the plastic timing chain guide on SL2's starting in 97? Were they corrected by then and were they a problem on SL1 or SL2 models?
Add to DHOOP's Reputation
Rate the quality of this post and help DHOOP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DHOOP is offline
Old 02-19-2000, 10:59 PM   #2
Saldana SC2 2K
Saldana SC2 2K will become famous soon enough
Default
On the pre 97' more of a prob. on the 2's because the length of the chain is longer. Supposed to be pretty good on the 1's if the oil is changed every 3k.
Not sure if any better on the ones after 97'. Maybe worse since they made the chains lighter or thinner because of noise. Only time will tell.
Anyone out there with a 97',98' or 99' with 150k on it and still have the original chain?
Add to Saldana SC2 2K's Reputation
Rate the quality of this post and help Saldana SC2 2K reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saldana SC2 2K is offline
Closed Thread
Timing Chain? Chain loose, engine cranks, no start DJboozeAlot S-Series Tech 18 10-21-2012 02:23 PM
Timing Chain or Timing Belt SL1/SL2 MikeJeffcoat S-Series Tech 1 06-21-2006 09:02 PM
timing chain or timing belt? burnoutking S-Series General 2 05-12-2006 10:00 AM
Timing belt or timing chain? tedsmith S-Series General 7 08-10-2005 12:17 AM
timing chain depraved Miscellaneous Tech 1 01-16-2003 05:21 PM
