Old 11-24-2005, 10:57 AM   #1
Vertigoomg
Vertigoomg is on a distinguished road
Vertigoomg's Avatar
Default Wtf
What is the difference between NGK plugs, Champion plugs, Bosch Super (non-platinum) plugs, Autolite plugs, ect. Is it such a big deal to use something other than NGK? I can get autolites for 1.29 vs 1.59 or 1.99 for NGK's.
Add to Vertigoomg's Reputation
Rate the quality of this post and help Vertigoomg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vertigoomg is offline   Reply With Quote
Old 11-24-2005, 01:40 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: Wtf
If you go to autolite.com and find out what ordinary copper plug they recommend it's probably pretty good.
For my SOHC, I think that's a 3926.
Walmart sells only the 3924 which is a cooler heat range. IIRC it's a (more) direct fit for the twin cam. Walmart's little computer says 3924 of course because they want to sell you a plug. It'll fit, and work, but might gunk up if you do a lot of short trip driving.
Even if you shop at a real auto parts store, if they have a small inventory, they will give you a plug that's not quite right.
NGKs are stock for many of the years, and to many people the $9 for a complete home tune-up is not an imposition. If you put in a $5 set of autolites and you get a slight stumble or .1 drop in MPG, you might find yourself wondering if the NGKs would have been better. It might not be the spark plug's fault of course, but if you're the type who wants perfection, that nagging feeling will eat at you.
You might see if Luke chimes in, he swaps his plugs every 5000 miles or so and has 430,000 miles on his car. If you like swapping more than every 30,000 miles as recommended cheap plugs might make sense. Even if the old plugs are properly gapped new plugs have those nice sharp corners to the electrodes. And if you burn lots of oil and foul plugs cheapies have their place.
Add to eljefino's Reputation
Old 11-24-2005, 01:48 PM   #3
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Default Re: Wtf
Is 70 cents really that big of a deal every 30K??? When all you look for is the cheapest part, that's what you end up with. You get what you pay for.
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline   Reply With Quote
Old 11-24-2005, 02:55 PM   #4
LowSC2
LowSC2 is on a distinguished road
LowSC2's Avatar
1999 SC1
1991 SL2
Default Re: Wtf
Get the NGK's. Worth the extra $0.70 a plug...
Jeff Silva ~ 91 SL2 - 11.809 @ 116.488mph
•Chilton & Haynes manuals are junk
•Changing the ECTS doesn't fix everything
Add to LowSC2's Reputation
Rate the quality of this post and help LowSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LowSC2 is offline   Reply With Quote
Old 11-24-2005, 11:01 PM   #5
Vertigoomg
Vertigoomg's Avatar
Default Re: Wtf
The question, however, is what makes them different. The NGK's for 2 bucks are the standard plugs... not v-powers. All of them look the same, feel the same, and (AFAIK) act the same. Even if it's to save .70 of a buck per plug, I'd rather do that than spend .70 of a buck for nothing.
wtf midwest S-Series General 5 04-06-2009 03:24 PM
wtf??? defy69 Ion General 4 02-23-2007 05:02 AM
WTF and FS JuicedL200 Classifieds 3 01-06-2004 11:24 PM
Wtf?? dixonba Miscellaneous Tech 9 11-19-2003 09:27 PM
