Old 03-27-2011, 08:31 PM   #1
Hi Milage Dave
Hi Milage Dave is on a distinguished road
1994 SL2
Default Belt Tensioner washer orientation
Read the posts but can't find details on washer orientation. Made boneheaded move, removed both the belt tensioner wheel and the idler wheel, before I realized the washers were not flat. I can only suspect that the washer has a toward motor orientation that is correct but don't know which way they should be installed.
Add to Hi Milage Dave's Reputation
Rate the quality of this post and help Hi Milage Dave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hi Milage Dave is offline   Reply With Quote
Old 03-27-2011, 10:47 PM   #2
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
Default Re: Belt Tensioner washer orientation
Just a guess on my part but I'd think that's from distortion from tightening the bolt. I'd be inclined to install it with the raised side against the bolt.
Tighten the belt tensioner idler pulley bolt 27 Nm (20 lbs ft).
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
off-track is offline   Reply With Quote
Old 03-28-2011, 12:31 AM   #3
SaturnFix
SaturnFix will become famous soon enoughSaturnFix will become famous soon enough
SaturnFix's Avatar
1996 SC2
Up to late model year 94 they used that curved one, and it was torqued to 35 lbs/ft rather than 20 lbs/ft. It should curve away from the pulley, so that it captures the bolt, if that makes sense.
Be sure to use conventional NGK spark plugs though, or the pulley can cause the belt to squeal.
What is your Saturn's oil economy?
Canada Saturn owners REVOLT!!! Improper factory spark plugs! c.c
If you are in the Southern Wisconsin area, check out: facebook.com/SaturnFix
Add to SaturnFix's Reputation
Rate the quality of this post and help SaturnFix reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnFix is offline   Reply With Quote
Belt squealing: new belt and good tensioner PlasticCarsRock S-Series Tech 23 04-14-2015 09:12 PM
Tensioner rattle is back -- even with new AC Delco tensioner and belt! 2003MercMaraude S-Series Tech 18 10-15-2010 07:23 PM
Belt Tensioner Pulley and belt replacement Drumstyx7a L-Series Tech 17 12-30-2009 02:01 AM
belt tensioner/removal of serp belt sc95auto S-Series Tech 2 07-02-2008 03:45 PM
Help Please 95 SL1 replaced belt tensioner now belt too tight A123jr S-Series Tech 10 05-12-2005 01:12 PM
