Old 03-17-2015, 01:27 PM   #1
xnizstudio
xnizstudio is on a distinguished road
Default Hello, swap questions
I've got a 97 SC2 and I bought a full swap a few months back. Ended up being a 2001+ swap (the valve covers looked almost the same but got them mixed up). So far the problem's I've ran into:
a) Had to re-work the exhaust system to fit the new manifold
b) Swapped out the intake manifold, fuel rail, and air filter/breather box.
I found that the MAP sensor and the TPS sensor are different.
Am I able to splice the harness and wire in the connectors for the 2001 MAP/TPS sensors and have my ECM properly read?
I'm looking into buying a 2002 SC2 3 door today and was thinking of just dropping the new stuff in the new car, and rebuilding the original 97 setup.
Comments? Anything else I might run into? I'm going home today after work to finish the intake swap. I originally put the older intake on the newer head and had serious vacuum leaks sucking oil all through the head.
Thanks!
Add to xnizstudio's Reputation
Rate the quality of this post and help xnizstudio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xnizstudio is offline   Reply With Quote
Old 03-23-2015, 11:53 AM   #2
saturny
saturny has a spectacular aura aboutsaturny has a spectacular aura about
Default Re: Hello, swap questions
Yes, you can splice the harness for the MAP sensor.
Just swap in the TPS that fits the connector on your harness. The engine/intake manifold doesn't care which TPS it is.
You'll also need to swap the throttle cable, and I think also the fuel lines.
Other than that - pretty much plug and play.
Add to saturny's Reputation
Rate the quality of this post and help saturny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturny is offline   Reply With Quote
Old 03-23-2015, 01:36 PM   #3
xnizstudio
Thanks for the reply. I found out that I had to run a new fuel line. The throttle cable worked fine (it clipped right on to the new throttle body).
Now my only thing left is that the new fuel rail does not have a fuel pressure regulator (something about going inline after 2000?) . So I am stuck again, unable to drive until I order out for an aftermarket regulator.
So far the swap has been a pain in the ass, but after hearing her start last night, this little thing is a monster. I'm running a 2001 swap in a 97 body with an aftermarket/custom exhaust system with the fuel pressure wide open until I get the new regulator. I'll have to drop some pics and a video some time of all the work me and my father put in to this thing.
Thanks!
swap questions? dougrobbins L-Series Tech 4 12-22-2011 10:56 AM
Going to look at a DOHC. questions questions for the swap. RBrown20 S-Series Mods 7 03-16-2009 07:53 AM
Swap Questions djsimm89 S-Series Mods 6 02-26-2008 12:33 PM
motor swap questions saturnman7 S-Series General 1 02-02-2006 10:52 PM
SL2 motor swap questions SCL2 S-Series Tech 7 02-16-2005 04:24 PM
