Old 06-02-2012, 11:44 AM   #1
kvonk
kvonk is on a distinguished road
Default Take a chance and just replace the head?
2000 Saturn SW2: Compression test w/ questionably functioning tester: Dry-130-40-40-130 and wet: 130-50-40-140. The car runs okay but with annoyingly low power on hills. The test numbers are suspect.
I did a leak down test with a DYI tester (design from a Youtube vid) and the only discernible air movement detected was when I put pressure into the #2 & 3 cylinders. What happened was air cam out of the #4 cylinder only.
I'm hoping it's just the head but am confused as hell at this point. Mantra: Please only be the valves and not rings etc.
196,000 miles on the car and it goes through a quart of oil every 400 miles or so. Finances preclude a rebuilt engine swap at this juncture.
Any help is most appreciated!
Add to kvonk's Reputation
Rate the quality of this post and help kvonk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kvonk is offline   Reply With Quote
Old 06-02-2012, 11:53 AM   #2
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1996 SC2
Default Re: Take a chance and just replace the head?
http://www.ebay.com/itm/SATURN-1-9-S...0d2eb2&vxp=mtr
A quart every 400 miles isn't the head alone and compression numbers like that I'd doubt would be the head alone. If you can do the work yourself you could get lucky and drill & re-ring the pistons at the same time as your replacing the head.
I got super lucky, a friend told me about a guy with a '97 SC1 for $100. Drove it home, found a DOHC and all kinds of new stuff worth a TON more then $100. Engine appears to burn 1/qt 2000+ miles.
Point: Would be worth checking classifieds for S-Series with busted subframes or for ones that have been used by a truck/SUV as a stopping block.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 06-02-2012, 12:50 PM   #3
aaron95sl2
aaron95sl2 is on a distinguished road
aaron95sl2's Avatar
Indeed, with those compression numbers and oil burning your rings are shot. Save up a little more money, rebuild the bottom end as well. Or, find a wrecked one with a decent engine in it.
1995 SL2 | Fully loaded | 140k on odometer | 4k on new engine w/ KB-S pistons - not a single drop of oil lost so far!
Add to aaron95sl2's Reputation
Rate the quality of this post and help aaron95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aaron95sl2 is offline   Reply With Quote
Old 06-02-2012, 02:12 PM   #4
madpogue
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
1996 SW2
The only way air pumped into one cylinder can come out another (and not anywhere else) is a head gasket leak. Did you have the dipstick and/or oil fill cap off for the leakdown test?
Add to madpogue's Reputation
Old 06-02-2012, 03:27 PM   #5
kvonk
The oil fill cap was off but not the dipstick.
Head remove/replace '93 SL2 Rhodes S-Series Tech 5 04-01-2012 04:46 PM
Replace head gasket oneringer S-Series Tech 5 12-07-2010 11:06 PM
How to replace head gasket dieselcamp S-Series Tech 3 12-06-2010 11:24 AM
02 SL1 SHOC with oil in coolant: replace head vs replace engine - need advice surreyman S-Series Tech 3 05-02-2010 12:24 PM
Replace head? aron944 L-Series Tech 1 04-21-2009 09:18 AM
