Old 08-16-2018, 10:25 AM   #21
Pitcher
Pitcher's Avatar
Default Re: Excessive oil consumption
I remember my Dad & BIL putting a Quart of ATF in the Oil to clean out a sludged engine back in the Mid 70's!
That was the Genesis of opening my brain up to experimenting with Additives!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Pitcher is online now   Reply With Quote
Old 08-16-2018, 04:20 PM   #22
Eiron
Eiron is on a distinguished road
Eiron's Avatar
1999 SW2
Originally Posted by Sc2Zr2 View Post
im still looking into running rotella t6, but am hesitant to put anything other than the manufacturers recommended 5w-30. don't want to cause anymore damage to any components due to lack of proper lubrication as i do plan to rebuild this engine in the near future.
I understand ....
as far as running a synthetic oil i may consider trying it out if i get a good deal on something, but at the rate im burning it i may as well just run the $12/gal chevron 5w-30 from Walmart. after rebuild synthetic all the way.
Yes, I was thinking about the high consumption and agree with you. However, instead of either 5W-30 conventional or 5W-xx synthetic, I'd run Chevron Delo or Shell Rotella 15W-40 (T4). These oils use so-called Group II+ base stocks and include the better dual-rated additive packages, so they'll provide better protection than 5W-30 and probably slow consumption a bit in the process. You might find similar benefits from a high-mileage 5W-30, but I'd expect higher consumption and I don't know how the cost compares to Delo or Rotella.
He's dead Jim!
You grab his tricorder, I'll get his wallet.
Add to Eiron's Reputation
Rate the quality of this post and help Eiron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eiron is offline   Reply With Quote
Old 08-16-2018, 05:46 PM   #23
nealt
nealt is on a distinguished road
1997 SC2
Burning a quart every 400 miles is a lot... I would go straight to the B-12 application on a warm engine.
This is what I did:
1) Clean spark plug wells
2) Loosen spark plugs on a cold engine
3) "Snug" the plugs back in
4) Start engine, let it warm up, shut it off
5) Drain oil in a clean container (to be reused)
6) Leave the drain plug off and put another container under the drain
7) Remove spark plugs
8) Pour 2-4 oz of B-12 through spark plug holes on a moderately warm engine. Sometimes I mixed the B-12 with PB Blaster Small Engine Tuneup
9) Hand crank or wiggle the serpentine belt to move the cylinders around a little to help the B-12 work in the rings
9) Let it drain out to oil pan
10) Add some more B-12 if it drained out quickly
11) Let it drain out
12) Once cylinders are drained or have waited long enough, put drain plug back on
13) Refill oil with the oil that was just drained
14) If B-12 is still in the cylinders try to get it out by cranking engine without plugs in (disconnect fuel pump or fuel pump relay)
15) Add a teaspoon of oil to each cylinder for lube (however, this will cause hard starting if it gets on plugs)
16) Put plugs back in
17) Reconnect fuel pump or relay if you disconnected it
18) Start up engine.
19) Engine will be EASIER to START if its still WARM, but it may take awhile and sound like crap for a little bit.
20) Take a drive
21) Change oil with new oil/filter or repeat the entire process again for another quick soak
Add to nealt's Reputation
Rate the quality of this post and help nealt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nealt is offline   Reply With Quote
Old 08-16-2018, 06:01 PM   #24
RobertGary1
1996 SC2
After the B-12 soak crank the engine with a towel over to catch liquid B-12 that didn't drain down. Then use compressed air and replace all the air in the cylinder several times over with shop air. Failure to do the last step will cause it to be very difficult to start since the cylinders are super rich. If you cannot do that at least start with the gas peddle pressed to the floor to put it in rich mode. Continue cranking with the gas peddle pressed until it starts to catch. It may be difficult to start.
Don't poor the B-12 directly into a hot engine. The vaporization temp on the B-12 isn't very high and it will just vaporize immediately.
-Robert
Old 08-17-2018, 10:29 AM   #25
alordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud ofalordofchaos has much to be proud of
Step 14, rather than disconnect fuel pump or fuel pump relay, pull the PCM-B fuse from the box under the hood.
Per OldNuc, that disables the fuel injectors and spark (no PCM signal - shuts off everything except the starter, and the battery / oil pressure lights)
Also, weigh down the rag over the spark plug wells, carefully and securely.
If you do it in haste and don't quite catch a corner, there is enough pressure when cranking to blow the rag up and you end up with MMO all over the hood and the walls of your garage. Ask me how I know
Old 08-17-2018, 10:56 AM   #26
nealt
1997 SC2
If the B-12 does it job, you probably won't have any left in the combustion chambers... it's pretty thin, and once it does it job, it will drain easier and there probably won't be any left on top of the cylinders. Only when I used MMO, did I have problems with it draining out. So you most likely will be able to skip step 14.
Old 08-17-2018, 11:58 AM   #27
RobertGary1
1996 SC2
Its the vapor that's left inside that causes the issue. There will be small amounts pooled on the top of the piston that maintains the vapor. Just need to blow the vapor out.
-Robert
Old 08-17-2018, 11:59 AM   #28
RobertGary1
1996 SC2
Pushing the gas peddle to the floor also disables the injectors. Its the flooded start mode in the PCM.
-Robert
Excessive fuel consumption when cold Commeatus S-Series Tech 11 11-22-2015 11:09 AM
Excessive oil consumption 06 Ion 2.2L vstringbassist Ion Tech 7 12-30-2014 06:26 PM
Excessive oil consumption, Grey oil color. jonc123 S-Series Tech 5 08-25-2014 11:01 PM
1998 SW2 - Excessive Oil Consumption Spectere S-Series Tech 5 09-13-2012 07:21 PM
Excessive oil consumption? dlc1265 Vue Tech 3 06-06-2008 11:34 PM
