Old 10-17-2019, 05:11 PM   #1
Homecoming1999
Homecoming1999 is on a distinguished road
Default Windshield wiper arm cap.......I need one!
Since you guys helped me track down a seatbelt, which I just ordered, the only other item that needs replacing is the plastic cap that fits over where the wiper arm is. Does anything have a lead on this part? I can get a set of wiper blades on Ebay which appears from the photo to come with it. But I cannot find it separate anywhere, Has been discontinued for years from GM....
1999 Saturn SL Homecoming
Thanks so much guys
Jason
Add to Homecoming1999's Reputation
Rate the quality of this post and help Homecoming1999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Homecoming1999 is offline   Reply With Quote
Old 10-17-2019, 07:08 PM   #2
Kaervak
Kaervak will become famous soon enoughKaervak will become famous soon enough
Kaervak's Avatar
Default Re: Windshield wiper arm cap.......I need one!
Should be able to find them at a junkyard, however I have a couple spares. Cost of shipping and they're yours.
Add to Kaervak's Reputation
Rate the quality of this post and help Kaervak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kaervak is offline   Reply With Quote
Old 10-17-2019, 07:26 PM   #3
Homecoming1999
Just sent you a message....maybe we can work something out....re..method of payment...
Old 10-17-2019, 07:47 PM   #4
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Thanks so much guys
Jason
When I went to the junkyard looking for the plastic cover that protected the hex nut on the wiper arm, I found most of them broken and just sitting in place. When I found one intact it looked as though the plastic covers were actually riveted into the wiper arm and could not be removed without breaking them.
Since all my original wiper arms needed was a good sanding and some black paint, I opted to use a 15mm black hex nut cover after removing the broken plastic covers.
I figured if I purchased a used set I could have the same problem with the plastic covers down the road.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-17-2019, 07:53 PM   #5
Homecoming1999
That looks fantastic...where did you get those from?
The caps that came on my car just slides in and out.....
Thank you!
Old 10-17-2019, 08:13 PM   #6
focusofheart
Thank you!
I purchased a set of various sizes of Dome Hex Bolt Caps from Amazon to use on the car.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 10-17-2019, 08:17 PM   #7
Homecoming1999
Thank you, I just bookmarked that...If I cant find a stock replacement I will order this for sure. It pretty much looks factory!
Jason
Old 10-17-2019, 08:45 PM   #8
trottida
trottida's Avatar
Believe it or not that part was also used on some models of Porsche. I can't recall who brought that forward but it's in this forum somewhere. A quick search tells me the Porsche part number is likely 92862862301. The Saturn part number is 21302902. The original post would likely confirm the part fitment and what exact model it comes from.
You can buy them here >> http://www.classicshop.porsche.com/p...862862301.html
or here >> https://www.amazon.com/GENUINE-PORSC.../dp/B00C7S1872
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-17-2019, 09:03 PM   #9
Homecoming1999
Thats freakin' incredible....Thank you!
Old 10-17-2019, 09:15 PM   #10
Homecoming1999
Just ordered 2...I can not believe a Porsche of all cars uses the same cap... I did the comparison, they are exactly the same!
Cheers
Jason
Old 10-18-2019, 02:24 PM   #11
Neat find! Not that those were super-expensive, but occasionally when a Porsche part is called for, you can also find a VW part that fits, is cheaper, and occasionally is better.
Example is plastic visor clips; don't recall the Porsche price exactly ($10~15?), but there is a metal VW clip for $4 or so.
The transmission clips for our Saturn trans cables are the same as certain Mercedes-Benz AT clips
Old 10-18-2019, 06:36 PM   #12
454cid
My car doesn't have covers. I always though they looked unfinished. Now, I know why.
1999 Chevy K3500
Add to 454cid's Reputation
Grease windshield wiper parts while windshield is out? Upstate Saturn S-Series General 6 05-09-2016 11:27 AM
windshield wiper does not work but rear wiper works vikasevan S-Series Tech 2 02-22-2014 12:28 AM
Windshield wiper arm - HELP IonVP Ion Tech 11 12-21-2013 04:23 PM
Windshield Wiper Arm Alikhy S-Series Tech 24 11-29-2011 12:51 AM
Windshield Wiper Blade Smearing on Windshield softwheat Aura General 7 02-13-2008 10:44 AM
