Old 04-26-2006, 03:44 PM   #1
brownmota
brownmota is on a distinguished road
brownmota's Avatar
1999 SL1
Wrench Rough engine start, High Idling, and Cold running engine(?)...
I am very new to this site and I have 3 problems concerning my 1999 SL2, 5-speed Manual Transmission, 150,000 mile 4-door Saturn.
1) When I go to start my engine I have to floor the accelerator in order for my car to start. In the event where I turn the ignition and do not floor the accelerator, the engine cranks and cranks but no start. This issue is erratic and lately has been happening more and more (5 times in the last 2 days). Please advise to what may be causing this (my feeling is the fuel pump).
2) Once the engine is on, it is good for me to drive. However, this is where my second problem occurs. As I drive I notice the engine revs real high; up to 3000 RPM as I change gears. If I come to a complete stop, it will rev at 3000 RPM and gradually (over a time span of about 15 seconds) rev down to 1500 RPM. Wheras before this problem, the car would idle at about 1000 RPM. ( I noticed this high revving soon after I got the thermostat housing and water pump changed about 2000 miles ago)
3) Besides this, the temperature gauge needle stays stuck at "C" (Cold) and it never moves up no matter how long the car is turned on (The longest I've had the car turned on and driven is about 45 minutes). My gut tells me that the high idling is caused by the "cold" running engine. My guess is that the computer is telling the fuel system to send more gas to the engine in order to warm the engine up to normal. Maybe this is a computer issue(?).
I recently (2000 miles ago) had the water pump changed for a new one and I also had the thermostat housing changed as well.
I'd like to take it to the dealer but I want to know what I"m getting myself into money-wise before I do.
I drive long distances in my Saturn so maybe the long trips have an affect(?). I drive about 200 miles a week and add another 1000 miles to that every 3rd week.
Thanks to anyone who helps me out with these problems.
Add to brownmota's Reputation
Rate the quality of this post and help brownmota reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brownmota is offline   Reply With Quote
Old 04-26-2006, 03:56 PM   #2
Carriere
Carriere is on a distinguished road
1995 SC1
Default Re: Rough engine start, High Idling, and Cold running engine(?)...
I am not sure if I will be the first one to tell you and I am not an expert by any means, i only know what I have learned on this site but if its a '99 I think everyone will tell you to change the old resin tipped ects with the new brass one from the dealer.
my car also Idled very high and I cleaned the egr as it was caked with carbon and that solved my high idle problem and the ects may solve your engine running at C as well as help you engine running too rich,
do you get back gas mileage?
Also after changing the ects and removing the egr for cleaning pull the pcm B fuse to reset the pcm.
thats all i know but maybe some other will concur with my thoughts and then again maybe not?
Add to Carriere's Reputation
Rate the quality of this post and help Carriere reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Carriere is offline   Reply With Quote
Old 04-26-2006, 04:34 PM   #3
brownmota
brownmota's Avatar
1999 SL1
Post Re: Rough engine start, High Idling, and Cold running engine(?)...
My gas mileage is getting worse. I used to get about 30 miles to the gallon HWY, now its down to about 22 miles.
I live in the Bay Area and Saturn mechanics will charge me upwards of $300 to diagnose the problems and extra to actually fix the problems.
I know of plenty of shops down in Los Angeles where I can get it done cheaper. Do you think it would be OK if I drove my High Idling, low temp Saturn 400 miles to get it fixed? I don't want to run the risk of being F.O.R.D. (lol).
Old 04-26-2006, 09:38 PM   #4
sunshn1972
sunshn1972 is on a distinguished road
sunshn1972's Avatar
Two ideas come to mind for the cold engine problem. When they replaced the thermostat housing did they also replace the thermostat?
However, I think the Engine Coolant Temperature Sensor (ECTS) is much more likely. Check the how-to section; I think the ECTS is push-pinned to the top of the list of how-to's. Make sure to replace the connector too if it's corroded.
I think if you check and replace the ECTS, some of your issues will be resolved. There may still be other problems to be resolved, but that would be a great start.
This space intentionally left blank.
Add to sunshn1972's Reputation
Rate the quality of this post and help sunshn1972 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sunshn1972 is offline   Reply With Quote
Old 04-26-2006, 09:53 PM   #5
wolfman
wolfman's Avatar
As others have posted....ECTS. There are instructions with pictures in the "How To Library" section of the board. It's about a $15 part that takes maybe 20 minutes to change.
Add to wolfman's Reputation
Old 04-27-2006, 10:01 AM   #6
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
ECTS... ECTS... ECTS.. (Engine Coolant Temperature sensor)! It very well may solve all of those problems. Cheap part, easy to do, even for someone that has no mechanical know-how. Just be sure to follow the instructions and if your connector has any corrosion on it, replace it. It can't be cleaned. I think even Autozone now sells the ECTS electrical connector, so you may not have to get that from the dealer. Get the ECTS from Saturn, though.
After replacing it, if you temperature is still low, replace the thermostat with a 195 degree one. Autozone only sells 185 degree, this is too cold.
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 04-29-2006, 06:55 PM   #7
saturnchap
saturnchap is on a distinguished road
Hi i've got the same symptons.My saturn runs cold it hardly reads on the guage at all.This has been going on for about a week.I've got to put her to the floor just to get her started and then she sends out black smoke for about a min.It seems that the temp hand and this rough start up is tied together somehow.This has been a loyal car.
Add to saturnchap's Reputation
Rate the quality of this post and help saturnchap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnchap is offline   Reply With Quote
Old 04-29-2006, 08:27 PM   #8
eljefino
eljefino's Avatar
1995 SW1
Add to eljefino's Reputation
Old 04-29-2006, 08:32 PM   #9
GreenSC2
GreenSC2 is on a distinguished road
GreenSC2's Avatar
Originally Posted by eljefino
If it looks like the one on the right side of picture, it is the old one. If it looks like the center one, with a bulgy part near the flats, it is the newer one.
You can tell which one it is just by looking.
It's not easy being Green(SC2). (IntelliTXT SUCKS)
I refuse to be a Lemming!!
Add to GreenSC2's Reputation
Rate the quality of this post and help GreenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GreenSC2 is offline   Reply With Quote
Old 04-29-2006, 11:54 PM   #10
Jinjo
Jinjo is on a distinguished road
Jinjo's Avatar
2001 SL2
Yeah just be careful when changing it, coolant does come out and it's like a fountain. Have the other one ready and perhaps another person with a bucket just underneathe the hole that coolant would come out of. You could also jack up the car on the drivers side so that it doesn't come out at all. I just recently did mine to find that it had already been done by the previous owner. Oh well.
Add to Jinjo's Reputation
Rate the quality of this post and help Jinjo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jinjo is offline   Reply With Quote
Old 04-30-2006, 09:50 AM   #11
saturnchap
Is there a fuse for this ECTS?Mine sure looks like the old one.Can codes be taken from a 97sl1 without a code tester?
Rough Engine Idling help!!! 1996SL2owner S-Series Tech 8 01-06-2010 06:37 PM
Running rough when idling berrymik S-Series Tech 6 01-16-2008 05:01 PM
rough running engine Eliot S-Series General 3 09-25-2007 01:18 PM
engine running rough duffygirl Ion General 12 06-06-2004 12:35 PM
Rough running engine deaconblooz1 S-Series Tech 24 10-26-2001 05:32 AM
