Old 01-22-2018, 01:30 PM   #1
Johnsonjf
Johnsonjf is on a distinguished road
Default Code P0420
I have a 2008 Saturn Vue Redline with 193K miles. Iím getting code P0420, Iíve replaced the O2 sensor and still have the same code. Is there any thing else I can do to fix this or is replacing the catalytic converts the only option?
Thank you,
Jeff
Johnsonjf is offline   Reply With Quote
Old 01-22-2018, 06:24 PM   #2
guyg
guyg will become famous soon enough
Default Re: Code P0420
Carefully check for small exhaust leaks between the front and rear O2 sensors, especially the flex hose. A shop vac can supply air to pressurize the exhaust, use a soap and water solution to check for any bubbles. Any slight leak may set a code.
guyg is offline   Reply With Quote
Code p0420 rockrtboy S-Series Mods 0 08-20-2016 12:07 AM
P0420 Code Help havok Vue Green Line 8 07-16-2015 11:49 AM
code P0420 Need help brianolda S-Series Tech 6 11-10-2011 12:39 AM
98 SL2 Code P0420 Snipew4 S-Series Tech 20 06-07-2008 09:14 PM
Another P0420 code alleninpa S-Series General 7 09-02-2007 03:03 AM
