Old 06-10-2008, 03:15 PM   #1
hd071502
hd071502 will become famous soon enough
Default replacement exhaust options
The flex piece connecting the manifold to the exhaust broke today. What are my options to replace this part. I see nothing listed as aftermarket except catback systems. Am I stuck going through Saturn for this part. My whole exhaust system is in rough shape, (100,000 miles of Wisconsin weather), it's going to need the timing belt and waterpump changed soon as well. Looks like the otherwise inexpensive vue is going to cost me some money now!
2002 Vue 3.0 AWD
2000 S-10 2.2 2WD
2006 GTO 6.0 RWD
2008 H-D Street Glide 1584cc 1WD!
Add to hd071502's Reputation
Rate the quality of this post and help hd071502 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hd071502 is offline   Reply With Quote
Old 06-10-2008, 03:36 PM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: replacement exhaust options
Just head to an exhaust shop. They should be able to weld in a new flex joint fairly inexpensively. It's a fairly common occurance up there.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 06-10-2008, 03:42 PM   #3
downtownbrown
downtownbrown is on a distinguished road
I had my flex pipe replaced, some hangars replaced and a piece of pipe replaced behind my cat-converter all for $220 (I think the flex pipe was $150) at a custom exhaust place in Toronto. Should be roughly that amount anywhere. Don't go to the dealer!
Add to downtownbrown's Reputation
Rate the quality of this post and help downtownbrown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
downtownbrown is offline   Reply With Quote
Old 06-10-2008, 04:30 PM   #4
hd071502
Exhaust shop is going to weld the flange where it broke. Should just cost me labor costs. Also when it was up in the air, we noticed support bearing for driveshaft was bad, I'll get that done right away too. I'll post back final results when done. Goes in Thursday morning.
2002 Vue 3.0 AWD
2000 S-10 2.2 2WD
2006 GTO 6.0 RWD
Old 06-14-2008, 09:32 AM   #5
hd071502
To follow up, shop did weld the flange, it was totaly broke from the flex pipe. They tacked it , removed it, and put a full bead around it, and reinstalled. They did a great job for $130.00. The driveshaft support bearing was shot, totally separated from the rubber. Had to buy that through Saturn for $187.00. (They sure must be proud of that bearing). That cost an additional $130.00 to have installed. Now I'm back on the road again.
2002 Vue 3.0 AWD
2000 S-10 2.2 2WD
2006 GTO 6.0 RWD
Old 06-14-2008, 11:00 AM   #6
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
My FWD cars before my Saturns never had a woven flex joint.
Was this a 90's innovation? Or a Saturn thing?
Add to BobbyP's Reputation
Old 06-14-2008, 12:14 PM   #7
Vuedoo Child
Vuedoo Child is on a distinguished road
Vuedoo Child's Avatar
2004 VUE Red Line
Actually a lot of manufactures use flex joints. Not on all-wheel drive either. For example, Ford uses them, and on Escorts, it was pretty common for them to go after years... Same on the Windstars too. Jaguar uses them on some models as well, though one of those is an AWD model. I believe it must have something to do with engine roll, and this being an effective means to keeping the rest of the exhaust in place while the engine does it's thing.
I liked the first one we bought so much I had to go back three days later and get another for myself! .....and I liked that one so much, I bought myself a Redline a year later!
Add to Vuedoo Child's Reputation
Rate the quality of this post and help Vuedoo Child reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vuedoo Child is offline   Reply With Quote
Catback Exhaust options BlackCoupe S-Series Mods 7 11-15-2008 01:24 AM
exhaust system options? sillysaturn S-Series Mods 15 07-31-2008 11:44 PM
exhaust options vinny9520 S-Series Mods 5 06-05-2008 01:09 PM
Exhaust Options OllieSC Mods and Performance 14 08-25-2002 07:55 AM
exhaust options for SL2? pbrown S-Series Mods 0 08-10-2002 11:09 PM
