Old 08-12-2019, 04:15 AM   #1
IL Trav
IL Trav is on a distinguished road
Dizzy 2004 Saturn ion 2.2 manual transmission little to no clutch pedal
We have a 2004 Saturn ion 3 we have replaced the clutch flywheel slave cylinder clutch master cylinder and had it bled by the GM dealer and there is very little clutch pressure still runs and drives but has Half to 1 3rd the clutch pedal as our other ion 3 and can’t seem to figure it out.. We have checked the Clutch pedal assembly and is had a very little bit of play I shamed it and put the master cylinder balls clipped back in the pedal and it just feels like you push the pedal halfway or more and then you get pressure..
Any help or input would be very much appreciated as we do not want to damage the transmission.. we have this one that has 210,000 miles (her’s) and mine that’s got 283,000 miles.. we love the cars they get good MPG and the have some pep to them for being 4 bangers
IL Trav is offline   Reply With Quote
Old 08-18-2019, 07:14 PM   #2
bern
2004 ION-2 Sedan
Default Re: 2004 Saturn ion 2.2 manual transmission little to no clutch pedal
You need to vacuum bleed the clutch. The vacuum needs to be pulled from the reservoir, leave bleeder screw closed. attach vacuum tool in way to the top of the reservoir that is air tight. pull the vacuum 2 mins, release, pump the clutch several time, and repeat several times. the vacuum tool needs to pull 26-27 inches. Hand type pumps may not work. I use a tool that works with shop air.
http://www.saturnfans.com/forums/sho...d.php?t=184345
Old 08-23-2019, 05:39 PM   #3
IL Trav
Took it to the dealer to be bled with the vacuum pump and this is how the car felt before any of the work was done I’m lost for what the problem is...
Old 09-08-2019, 01:27 PM   #4
bern
2004 ION-2 Sedan
If the is still low then the clutch system still may have air in it.
Note most technicians don't know how to bleed these systems. did you share the information above with the technician (not the service advisor)? Is it fixed now and if so what done to fix it?
FFR: brake and clutch pedal pad cover manual transmission Waiex191 S-Series Tech 3 09-18-2018 10:33 PM
2004 Saturn vue 2.2l 4l manual clutch problem TRV Vue General 9 06-25-2018 01:08 PM
2004 Saturn Vue - Will Not Shift into Reverse - Manual Transmission JLROhio Vue General 1 05-11-2017 06:35 PM
2004 Saturn Vue 4 manual transmission. Sadiaz7 Vue Tech 3 10-09-2013 10:34 PM
1997 Saturn SL2 manual...Something broke, can't shift into gear. Shakey clutch pedal Felixx S-Series General 7 04-26-2013 12:45 PM
