Old 02-10-2009, 08:28 PM   #1
dirkisthe1
dirkisthe1 is on a distinguished road
1997 SL1
Default What shocks to buy for sprint extreme springs?
Hey guys Need some advice
I got a 1997 sl1 that I got some cheap sprint extreme springs for. I got 260 km on the shocks and they obviously need replacing before I put those springs on. So what shocks do I get ? I can really only find these kyb gr2 out there. I have read on here that they might not be very good for such en extreme lowering. Please help. I have the springs and dont want em to just rott in the box. Thanks guys.
-Dirk
dirkisthe1 is offline   Reply With Quote
Old 02-10-2009, 10:04 PM   #2
S3aturnR
S3aturnR's Avatar
1999 SL1
Default Re: What shocks to buy for sprint extreme springs?
-Dirk
yup, you'll prolly be stuck with the kyb struts. they work, but not very well. definitely better than the stockers. good luck!
s3aturnr
Old 02-10-2009, 11:38 PM   #3
97sleeper
97sleeper is on a distinguished road
97sleeper's Avatar
The best option that we have without getting some custom made are the KYB's.
A good Saturn is a good sleeper -J. Beanan
97 SL2
-N/A sleeper build, check my profile the list
93 Ford Exploder
-5spd 4WD 4.0L V6
-800W sound system
-4 100W lights
97sleeper is offline   Reply With Quote
Old 02-11-2009, 12:07 AM   #4
dirkisthe1
1997 SL1
From what I have been reading kyb gr2 will wear out really fast with that extreme drop and basically give me a crappy ride all in all. I have the springs so I got use em lol. So I have been looking around the net and came across these
w w w.streetbeatcustoms.com/Matrix/Shocks/Coilover-Shock-Kit-_-8023/566274/
A coilover shock kit? Never heard of it before. As I understand they mount on top of my shocks which will probably by those kyb gr2 at this point and will be adjustable so that the drop isn't as much and then hence i wont wear out the kyb gr2. Do I understand that correct? Please help I am new to this whole car fixing and modifying. Thanks alot guys.
-guess i cant post the url Ill try to take out the w w w., but its w w w. then streetbeatcustoms.com/Matrix/Shocks/Coilover-Shock-Kit-_-8023/566274/
-Dirk
Old 02-11-2009, 12:59 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
you can get KYB GR-2 struts or send your OE Saturn struts to TrueChoice in Ohio and they will cut them open and put a Koni insert inside. Then you can adjust them. www.truechoicekoniracingservices.com is a link to them. I've used KYB GR-2 struts with H&R Sport and Eibach Pro-Kit spring and nothing bad happened in 100,000 miles of use. However I like the idea of being able to adjust the Koni-in-a-Saturn strut housing
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 02-11-2009, 03:20 AM   #6
93SC2'in
93SC2'in is on a distinguished road
93SC2'in's Avatar
1993 SC2
-Dirk
the little planet button with the chain links in front of it is your friend
but what does everyone think of this coilover kit? it sounds iffy
http://www.streetbeatcustoms.com/Mat..._-8023/566274/
93 SC2, 5-speed, <dead and gone>
95 SL2 5-speed, oem header, gsi TB, sprint 2.0, kyb gr2's, wb02, SAFCII, CAI, 17"s
Speed Kills - save lives, Drive a honda
93SC2'in is offline   Reply With Quote
Old 02-11-2009, 04:13 AM   #7
97sleeper
97sleeper's Avatar
They look like the junk that you find on E-bay only off of a different website. Ya either gotta go with what you have or sell the springs and get something different. Also, if you want coilovers, you ARE going to need to spend a lot of money:
Agility Coilovers $1400
AMR Engineering $1300
I don't know how close the AMR price is but you get my point, otherwise, your "coilover" suspension will be junk.
97 SL2
93 Ford Exploder
-5spd 4WD 4.0L V6
-800W sound system
-4 100W lights
Old 02-11-2009, 09:51 AM   #8
dirkisthe1
1997 SL1
I like the idea of koni shocks in my saturn. Any idea how expensive that would be? Has anyone do that? Also what exactly is a coilover kit? What do they do? Sounds like these lowering springs were a waste. Are they at least well built, so I spend the money on the custom koni's I wont be disappointed in the springs? Thanks for all the help guys. Saturns ROCK !
-Dirk
Old 02-11-2009, 10:26 AM   #9
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
Coil overs are fully adjustable. They have a nut that slides the spring cap down or up, allowing you to make the suspension loose or tighter, depending on what you wish to do. Where as a strut isn't adjustable. Unless you are road racing they don't serve a purpose for the cost.
Fox Slaughter is offline   Reply With Quote
Old 02-11-2009, 10:58 AM   #10
OnDaGround
OnDaGround's Avatar
1993 SC2
now I am no suspension guru, but can these cars take the shock inserts because they make them in different heights.
Saturnless...
Old 02-11-2009, 11:29 AM   #11
Low Saturn
Low Saturn's Avatar
2007 AURA XR
KYB's + Sprint Extremes = (unless you never, ever have anything in the trunk or a person in the back seat). KYB's are no better than stockers or stock replacements for the rear.
Spring Tech (ST) struts + Sprint Extremes = (Only problem is that they can be hard to find)
EDIT: Found some http://cgi.ebay.com/ebaymotors/SHOCK...1%7C240%3A1318
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 02-11-2009, 11:39 AM   #12
92SL1Mann
92SL1Mann is on a distinguished road
1992 SL1
werent the ST's stiffer in the back and the KYB's stiffer up front? (thought i read 30% somewhere) Would that not make the ideal set up KYB in the fron and some ST's in the back?
1992 SL1, 376,000Kms
1996 SC2, 243,000Kms
92SL1Mann is offline   Reply With Quote
Old 02-11-2009, 03:23 PM   #13
93SC2'in
93SC2'in's Avatar
1993 SC2
this is exactly why i went with KYB's in the front and S/T's in the rear well as soon as i get them on the car that is
Old 02-11-2009, 05:37 PM   #14
92SL1Mann
1992 SL1
Anyone here running ALL Springtechs?
Old 02-12-2009, 12:11 AM   #15
eRic 02sc2
eRic 02sc2's Avatar
-Dirk
it will cost $375 each ($1500 total) for TrueChoice to cut open and put Koni adjustable inserts in your Saturn struts. the Koni inserts themselves are $200 each if you need to replace them in the future. TrueChoice can make your OE struts into coilovers for additional money. I'm not sure what that cost but when SPS was selling a Koni coilover kit they charged $2399 -- including springs
eRic 02sc2
Old 02-14-2009, 09:11 PM   #16
dirkisthe1
1997 SL1
Ok I got the sprint springs and sprint tech struts for the back, kyb gr2 for the front. Anything else I need to go a suspension work over? There are all kinds of things I see online for shocks struts, such as mounts, bellows, etc. What if any of those things do I need? Or will my new shocks have all that. My friend and I will be installing them, just wondering if there are any other parts I should be ordering for a complete suspension/strut overhaul. Thanks alot guys.
-Dirk
Old 02-16-2009, 01:01 AM   #17
97sleeper
97sleeper's Avatar
I would replace all of your strut mounts. I replaced all of mine with KYB mounts and no issues but some of the guys around here will say that they are junk mounts. Anything else is really by preference.
97 SL2
93 Ford Exploder
-5spd 4WD 4.0L V6
-800W sound system
-4 100W lights
Old 02-24-2009, 05:58 AM   #18
dirkisthe1
1997 SL1
Well I got the sprint springs in, running on spring tech shocks on front and back. Waiting for money for kyb gr2's upfront. Also will be replacing the mounts with kyb mounts. Right now its a cool new low ride. Very bumpy. But I corner in my saturn like never before. Thanks for all the imput gentlemen. I will be posting back with updates.
Old 02-28-2009, 07:14 PM   #19
ivymotorsports
ivymotorsports is on a distinguished road
Where y'all getting the Kyb mounts from online??
ivymotorsports is offline   Reply With Quote
Old 03-03-2009, 12:46 PM   #20
97sleeper
97sleeper's Avatar
I got mine at Tire Rack - strut mounts
97 SL2
93 Ford Exploder
-5spd 4WD 4.0L V6
-800W sound system
-4 100W lights
sprint extreme 2.5 lowering springs fastion Classifieds 1 02-17-2005 03:41 PM
FS: Sprint Extreme Lowering Springs 2.5" Drop LimitedSC2k1 Classifieds 9 03-28-2004 11:59 PM
Shocks and Stuts for my Sprint Springs? Sprint Spring Review... warmonger Ion General 5 02-28-2004 09:51 PM
Sprint Springs... Rob1998SL2 Mods and Performance 8 10-05-2003 03:12 PM
Sprint Extreme springs $110 shipped fastwheels Classifieds 2 01-22-2003 11:26 AM
