Old 05-22-2006, 09:59 PM   #1
jimidonovan
jimidonovan is on a distinguished road
Wrench 94 Saturn SL1 - 6 SES Codes
94 Saturn SL1 4 Dr Sedan
4 Cyl 1.9L
I have a 94 Saturn SL1 with 127,000 miles on it. The Service Engine Soon light will turn on and off usually once it gets up to the normal operating temp then it begins to jump and it seems like its missing. I checked the codes with a paper clip and got 6 of them. I called Saturn and the manager told me what they were.
19 - 6x Signal Fault
22 - Throttle Position
26 - QDM (Quad Driver) Error
32 - EGR Fault
35 - RPM Out Of Range
42 - IC (Idle Air Control Grounded)
He also told me it may be the Ignition Modual or sensors. I replaced the fuel filter and that didnt work. So if anybody has any suggestions on how to fix this problem it would be greatly appreciated.
Thanks Jimi
Add to jimidonovan's Reputation
Rate the quality of this post and help jimidonovan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jimidonovan is offline   Reply With Quote
Old 05-22-2006, 11:50 PM   #2
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
Default Re: 94 Saturn SL1 - 6 SES Codes
Wow, thats alot of codes. You might want to disconnect the battery to clear them, then drive the car again and see which ones reset themselves. Some of those could be old codes from previous repairs that weren't cleared.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 05-23-2006, 02:40 AM   #3
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
4 Cyl 1.9L
32 - EGR Fault
For a quick and dirty diagnosis over the web, it sounds as if you are in need of an ignition control module (causing code 19 and 35) a new EGR valve (causing codes 26 and 32) and possibly new TB sensors (TPS and IAC) or just a good cleaning and making sure connectors are tight. But that is just a quick diagnosis. A bad MAP sensor can cause some of these codes too though....
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-23-2006, 06:58 PM   #4
jimidonovan
Thumbs Up Re: 94 Saturn SL1 - 6 SES Codes
Ok thank you for the quick reply I disconnected the battery and Im going to drive it around and test the codes again. Ill get back to you and let you know which codes come back up.
Thanks again
Jimi
Old 07-20-2006, 04:16 PM   #5
jimidonovan
Ok I disconnected the battery and I changed a few parts.
1. Map Sensor
2. Ignition module
3. Both Coils
4. Spark plugs and wires
5. EGR valve
6. EGR Solinoid
Now Im still getting SES codes 41 and 42. Here is the definitions I found online although Im not sure what the A's B's and C's are supposed to mean.
41
Ignition control circuit open or shorted
41A
EST circuit open
41B
EST circuit shorted
42
EST bypass, open or shorted
42A
Bypass circuit grounded
42B
Bypass circuit open
42C
Bypass circuit shorted
Please Help
Thanks
2000 SL1 SES with codes HELP Iceman15154 S-Series General 2 11-08-2009 08:22 AM
1996 SL1 SES no codes cheese07 S-Series Tech 8 03-21-2008 02:56 AM
93 SL1 ses codes 32 & 45 loweyj S-Series Tech 8 04-17-2007 05:43 PM
95 SL1 SES codes 22 and 76 GySgt_V S-Series Tech 2 06-16-2006 11:07 PM
95 SL1 SES codes 22 and 76 GySgt_V S-Series General 0 06-12-2006 07:04 PM
