Closed Thread
Old 02-12-2005, 11:43 PM   #1
RebelExtrm02
RebelExtrm02 is on a distinguished road
Default Timing Chain Fix (newbie)
First off, I am not familiar with saturns, at all.
I was looking through the Weekly Trader and seen an ad for a '95 Saturn LS2 4 door automatic (needs engine work) $395. So I called the lot that had it. They said the problem was the timing. Aparently the previous owner took the engine apart and didn't put the timing assembly together right and it won't start. The lot said they bought it this way and couldn't tell me much more. My question is, Is the timing assembly easy to diagnose/fix, if so what are some possiblilities/solutions to this problem?
Add to RebelExtrm02's Reputation
Rate the quality of this post and help RebelExtrm02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RebelExtrm02 is offline
Old 02-13-2005, 12:02 AM   #2
Sky King
Sky King is on a distinguished road
Sky King's Avatar
1999 SC2
Default Re: Timing Chain Fix (newbie)
Other than the engine problem, what condition is the rest of the car? And obviously, untill you get the engine running you won't really know about some of the other things such as air conditioning and so on. But depending on how badly the "previous owner" mis timed the cams, you could be looking at some other issues such as bent valves, damaged pistons. The timing chain in itself is not really too difficult depend on your mechanical abilities. Personally, if the rest of the car was in good shape and all it needed was a timing chain set, I would buy the car for that money. I do wonder what else the "previous owner" may have screwed up. There is only one thing worse than somebody who is not mechanically inclined working on your car, that is somebody who is not mechanically inclined and doesn't know it.
By the way, it's an SL-2
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sky King is offline
Old 02-13-2005, 12:05 AM   #3
Sky King
Sky King's Avatar
1999 SC2
I said it was an SL-2 forgetting about the LS series. But since the LS was not available in '95, if it is a '95 it is a SL-2, if it IS an L series then it is newer than '95
Sky King is offline
Old 02-13-2005, 12:11 AM   #4
ScurriVision
ScurriVision is on a distinguished road
ScurriVision's Avatar
2005 VUE Red Line
2000 SW2
Wrench Re: Timing Chain Fix (newbie)
I agree completely with the above post!! If I were buying this vehicle, I would simply "ASSUME" it needs a (REAL) total engine rebuild, or engine swap. That way you are prepared mentally & hopefully financially for the worse. Next, I'd start looking at pricing used SL2 engines... to get an idea of what they are going for.
Good luck & keep us posted on whether or not you buy it!
Add to ScurriVision's Reputation
Rate the quality of this post and help ScurriVision reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ScurriVision is offline
Old 02-13-2005, 04:58 AM   #5
amazinghl
I'd just swap an engine, it's probably easier than figure out why the one in there isn't working.
Add to amazinghl's Reputation
Rate the quality of this post and help amazinghl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
amazinghl is offline
Old 02-13-2005, 06:25 AM   #6
EzDi
EzDi is on a distinguished road
EzDi's Avatar
It's hard to mess up the timing in a way that it won't run but won't trash the valves...
Add to EzDi's Reputation
Rate the quality of this post and help EzDi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EzDi is offline
Old 02-13-2005, 09:19 AM   #7
chrispel
chrispel is on a distinguished road
chrispel's Avatar
2001 SL2
That is not true. I think anything over 12 degrees will cause the car not to run and valves will be bent. If I remember correctly each tooth on the cams sprocket is 9 degrees so all it would take is for one of the gears to be out of time 2 teeth.
Add to chrispel's Reputation
Rate the quality of this post and help chrispel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chrispel is offline
Old 02-13-2005, 12:52 PM   #8
RebelExtrm02
Thanx for the input. The rest of the car is great. I appologize for the mixup in the model. I knew it was a SL-2 thats why i'm in the S series forums. LOL I appreciate the advice.
Old 02-13-2005, 02:54 PM   #9
Nowhere Man
Nowhere Man is on a distinguished road
Nowhere Man's Avatar
1995 SW2
If the previous owner tried to do a timing chain job and failed. That means it never started after he messed with it, which also means that there isn't any piston damage. The starter can make the pistons smack into the valves on startup, thus bending them, but I dont think the pistons would be damaged just from the starter. Just get a rebuilt or used head, time it correctly, and for at most $400 you have a perfectly fine, running car.
95' SW2
131,000 Miles
32-MPG avg.
Add to Nowhere Man's Reputation
Rate the quality of this post and help Nowhere Man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nowhere Man is offline
Old 02-13-2005, 03:21 PM   #10
Razorbak
Razorbak is on a distinguished road
Razorbak's Avatar
1996 SL2
I would also not discount too heavily the possibility that the previous owner lied to the junkyard when they scrapped the car, nor would I discount the possibility that the junkyard might be sugar coating what really happened. Caveat emptor.
Having said all that, for just $395, your risk is pretty limited.
*Edit*
Just re-read the initial post. Is this being sold by a used car lot or a junkyard? (I thought it was a junkyard initially, but it sounds like it may be a used car lot.)
Is this an "as is/where is" sale, where you have no recourse to the seller, or are they willing to provide some type of guarantee?
Add to Razorbak's Reputation
Rate the quality of this post and help Razorbak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Razorbak is offline
Old 02-13-2005, 04:26 PM   #11
Low Saturn
Low Saturn's Avatar
2000 SC2
Reguardless the problems with the engine, I'd get it. Either pick up a junkyard engine or fix it yourself. For $395 this can be a great and not to expensive learning experience.
Low Saturn is offline
Old 02-13-2005, 09:51 PM   #12
Luke
Luke's Avatar
Default Junk Yard vs Used Car Lot
>> RebelExtrm02 <<
> I called the lot that had it. They said the problem was the timing. Aparently the previous owner took the engine apart and didn't put the timing assembly together right and it won't start. The lot said they bought it this way and couldn't tell me much more.<
Doesn't sound like a junkyard to me, but a "used car lot"
Razorbak
My hat's off to your analysis
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline
Closed Thread
Timing Chain? Chain loose, engine cranks, no start DJboozeAlot S-Series Tech 18 10-21-2012 02:23 PM
Timing Chain or Timing Belt SL1/SL2 MikeJeffcoat S-Series Tech 1 06-21-2006 09:02 PM
How can I tell if my timing chain is going out? Chad9932000 L-Series Tech 6 05-22-2006 11:26 PM
timing chain or timing belt? burnoutking S-Series General 2 05-12-2006 10:00 AM
Timing belt or timing chain? tedsmith S-Series General 7 08-10-2005 12:17 AM
