Old 04-07-2018, 11:34 PM   #1
oreocookie
oreocookie is on a distinguished road
Default wheel hub bearing replacement
how difficult is to replace wheel hub bearing on 08 vue xe awd
steps, torque specs.
thanks
Add to oreocookie's Reputation
Rate the quality of this post and help oreocookie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oreocookie is offline   Reply With Quote
Old 04-08-2018, 12:01 PM   #2
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default Re: wheel hub bearing replacement
thanks
Which bearing?
Mostly depends on amount of salt exposure. On my '09 Vue, I got my front passenger side bolts out...big nut off, disc brake carrier off, hub bolts off, and couldn't get the bearing assembly off the knuckle. Corrosion bonded.
I tried Map heat and slide hammer. No go. Had to reassemble and drove the car to top local mechanic with Acetylene aka big heat to break the bond. My car is very low miles as well but was driven in salt in Michigan winter.
Pics below:
Add to gm7's Reputation
Rate the quality of this post and help gm7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gm7 is offline   Reply With Quote
Wheel Bearing Replacement black_vue Vue Red Line 11 12-03-2016 10:00 AM
Rear Wheel Hub/Bearing Replacement uhlemd Vue Tech 22 06-12-2016 02:17 PM
08 Vue Xr Rear wheel bearing replacement skapplin Vue Tech 2 02-20-2015 12:00 AM
06 Vue Wheel Bearing Hub Replacement dleclerc Vue Tech 3 01-03-2013 11:58 PM
DIY for wheel bearing replacement? N2MYE30 S-Series Tech 4 01-13-2010 11:13 AM
