Old 07-07-2011, 10:48 AM   #1
MeSpdRacer
MeSpdRacer is on a distinguished road
1993 SC2
Default SC2 circle track racecar
I have been tweaking my 1993 sc2 to get the power I need to run with the hondas on my local 3/8 asphalt circle track and so far it is doing well! I have a header and straight pipe for exhaust and a custom air intake. I blocked off the EGR, unplugged the o2 and air intake temp sensor. I am currently looking for a TBI from a geo storm for it. Any other tips trick you guys might know to get just a tweak more out of it? Cant make "motor mods" because of rules. Oh it's, of course, tottally gutted for wieght including Interior and anything not needed under the hood. (Ac and pwer steering).
Also trying to get even more camber out of all the wheels. Already slotted the mount holes in front but now hitting the strut. Thanks!!
Add to MeSpdRacer's Reputation
Rate the quality of this post and help MeSpdRacer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MeSpdRacer is offline   Reply With Quote
Old 07-07-2011, 11:18 AM   #2
swansong
swansong is on a distinguished road
2000 SC2
Default Re: SC2 circle track racecar
There's a guy that has two for sale in the Classifieds section: http://www.saturnfans.com/classified...uct/4113/cat/6
Mine - 2002 Ford Focus SVT, 127k, Sonic Blue
Was mine - 2002 SL1, Auto, Cranberry, bought at a neglected 110k, sold at 125k
Wife's - 2000 SC2, Auto, 116k, Red, bought at a pampered 57k
Add to swansong's Reputation
Rate the quality of this post and help swansong reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swansong is offline   Reply With Quote
Old 07-07-2011, 12:33 PM   #3
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
You can also slot the upper mount holes. I slotted mine for Caster. Which is sad or our cars.
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline   Reply With Quote
Old 07-07-2011, 01:43 PM   #4
MeSpdRacer
1993 SC2
Thanks swansong! and Cloud I already did that as much as I could but we cannot modify the main center hole so it didnt do much for me. It is pushed all the way over and the top of the strut is against the metal
Thanks!
Old 07-07-2011, 03:00 PM   #5
cloud819
cloud819's Avatar
So you've slotted the bottom (where the strut connects to the spindle/bearing holder) and the top (3 strut mount holes)?
With those and and maybe a camber bolt you should be past -3 degrees.
Old 07-07-2011, 03:59 PM   #6
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Would an adjustable fuel pressure regulator violate your rules?
http://www.evilplastic.com/92mod7.htm#fpr
Lane turned down the pressure and gained some power.
Also, check out the rest of Lane's site for all sorts of ideas.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 07-07-2011, 08:03 PM   #7
MeSpdRacer
1993 SC2
Cloud I can get alot more out of it but I am hitting the strut with the top of the tire. I need to figure out how to get the tire away. I moved the top and bottom but cant go anymore. I was told to "put a bend" in the strut to stiffen it and move it in lol. I need a different offset on the wheel but we have to run a "factory" wheel whether steel or aluminum.
Thanks Tom and no adjustable aftermarkets but I did fine this on SaturnWIki.net
91-94 fuel pressure regulators are non-adjustable.
95-97 fuel pressure regulators are adjustable.
91-94 aluminum fuel rails will not fit 95-97 intake manifolds due to the bolt pattern and fuel lines being plastic.
Any aftermarket adjustable FPR for an 1992 through 1996 LT-1 Corvette will bolt right up to a Saturn fuel rail
If thats the case I think that means I can get a regulator from a 95-97 and still remain "factory" on my 93. hmmmm
Old 07-09-2011, 12:15 AM   #8
5ton
5ton is on a distinguished road
1993 SC2
1993 SC2
Hey cool *****...I race these to.
Duel intake cam mod. Also gear your car rite. Big track use the single cam tranny. Small track use duel cam tranny.
You will beat them 200hp+ Hondas and once you do laugh in there face
Add to 5ton's Reputation
Rate the quality of this post and help 5ton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
5ton is offline   Reply With Quote
circle track racing SC2 MeSpdRacer S-Series Mods 14 11-06-2012 10:58 AM
95 Wagon Sohc Racecar to Dohc Swap SaturnBandit52 S-Series Mods 2 10-04-2010 10:59 AM
1995 Saturn Sl2 Racecar aruschmann84 S-Series Mods 22 05-03-2010 06:40 PM
FOR SALE 1997 SC2 RACECAR Solo2 EP cyberbill Classifieds 18 10-15-2004 07:44 AM
Turning circle dave Suggestion Box 8 05-03-2000 04:02 AM
