Old 10-11-2013, 12:48 AM   #1
1badnotch
1badnotch is on a distinguished road
Default my new to me '99 SL2
I just picked up a '99 SL2,auto,silver ext,gray int,pdl,cc,rke with 105k on it for $2200. It is in pretty good shape. I have done a few things to it like new:t-stat,water pump,ects, flushed coolant,trans filter,trans fluid,ngk plugs,ntk o2 sensor. Mods:quad headlight mod,24/20 inch wipers,modified airbox. I got a ton of info from this site so far.
2006 Vue Redline,black,AWD,3.5 V6,Saturn all weather mats.
1badnotch is offline   Reply With Quote
Old 10-11-2013, 11:41 AM   #2
Default Re: my new to me '99 SL2
Nice! Your car will appreciate the attention
What airbox mod did you do?
Welcome aboard!
Old 10-11-2013, 11:46 AM   #3
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Welcome to the forum and you get 2 brownie points ( non redeemable ) for doing your homework.
Is this your first Saturn ? Keep an eye on things - especially oil and coolant, and the pavement where you park it.
97 sl2 a/t 104 K
Old 10-11-2013, 06:13 PM   #4
1badnotch
Thanks for the welcome. This is my first Saturn. I have been on here researching for about a month now. I found a lot of great info on these cars,which made things a lot easier. I have been keeping a close eye on the engine oil and coolant. It uses a small amount of oil,but not too bad.
As far as the airbox,I removed the resonator above the radiator,airbox inlet tube that is riveted in and cut out the corner of the airbox next to the battery. I am also going to get a K&N drop in filter soon.
Old 10-11-2013, 09:57 PM   #5
el diablo viejo
1994 SW1
Synthetic oil generally will help to keep the oil usage from getting worse, if you can justify the extra cost and it is not burning a lot. It should also get you another 1-2 mpg.
97 sl2 a/t 104 K
