Old 02-20-2014, 02:45 AM   #1
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Default Scrapping '96 SC2
Scrapping my brother's Red '96 SC2 this Saturday. He wrecked it in the front, then took the motor and trans and swapped it to another one....
Still have most of the parts from the front doors on back, thought I'd post here and let anybody that needed parts speak up before I send it off. Can get pics on request.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
wi111y is offline   Reply With Quote
Old 02-20-2014, 08:41 PM   #2
Chub
Chub is just really niceChub is just really niceChub is just really niceChub is just really nice
Chub's Avatar
Default Re: Scrapping '96 SC2
Does it have a black interior and are the trim panels in decent condition? I am very much looking for decent condition black trim panels for the 95-96 SC2 as well as a black dashboard. I am swapping my car from the ugly brown interior to the black one and I am still looking for some pieces.
1995 SC2: Back on the road again after my second engine rebuild in two years.
Chub is offline   Reply With Quote
Old 02-21-2014, 12:33 AM   #3
wi111y
1995 SL
1995 SW2
Sorry it's tan....
I can say on another note, that I used the Duplicolor vinyl spray paint on my door panels, and they came out really nice.
Doesn't scratch off like people say it does, and it hasn't faded at all.
Old 02-21-2014, 02:16 AM   #4
Chub
Chub's Avatar
Originally Posted by wi111y View Post
Sorry it's tan....
Well, that's sad about the car but thank you for the tip on painting. I was going to try doing it on the A-pillars and sunroof stuff since you can't get them in black if you wanted. It is good to know that some success in this type of endeavor has been achieved.
I guess on the sunroof note, did it have one and did it work? I am looking for a working module to use as a guide to fabricate one out aluminum. The one I converted from a 1995 SL2 broke already since the plastic pieces are getting so brittle from age. I guess I should have thought I was lucky enough to find a car with 190K miles and a working sunroof in the junkyard. I will probably not find another working one for some time.
Old 02-21-2014, 02:22 AM   #5
wi111y
1995 SL
1995 SW2
Yes it had one, and last I checked it worked... I'll have to ask my brother for certain.
I have no idea how to take that out though, but I can try if you want it. Or you could possibly come take a stab at it depending what part of PA you're from.
Old 02-21-2014, 04:24 AM   #6
Chub
Chub's Avatar
I am quite interested in getting another sunroof module, however, I do not want you to have to go out of your way to get it out of the car. I would gladly take it out myself but there is no way I would be able to do it this weekend before the car was scrapped. I live about 2hrs away from Harrisburg (I'm in far east-central PA). Thanks for the offer though.
Old 02-21-2014, 10:21 AM   #7
KDulcimer
KDulcimer is on a distinguished road
1996 SW2
What is the condition of the subframe?
SaturnFans helper map: http://bit.ly/1uDorVF
1998 SW2 & 2002 SL sold, but I still see them around!
Purchased automatic 1996 SW2 September 2018.
KDulcimer is offline   Reply With Quote
Old 02-21-2014, 11:00 AM   #8
mars2878
mars2878 is on a distinguished road
too bad you weren't closer, I might have interested in spare parts. good luck on the sale though.
mars2878 is offline   Reply With Quote
Old 02-21-2014, 05:55 PM   #9
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Sunroof module comes out quick if you dont mind destroying the headliner.
Once you have either carefully removed headliner, or just ripped it out , You remove the 6 torx screws holding the glass in place. You then disconnect the power wires to the motor. disconnect or snip the 4 drain tubes at each corner. Then there is about 10 10mm bolts.
If its a working module, its worth hanging onto.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
blue92 is offline   Reply With Quote
Old 02-21-2014, 07:11 PM   #10
Busket
Busket is on a distinguished road
1996 SC2
I know you said it was wrecked from the front but is there any chance the driver side fender is still good?
1996 SC2. Auto to Manual conversion, 5th gear swap, Dual roll pin for diff pin, B&G springs on KYB GR-2 Struts, AEM CAI (unlike Chub mine actually is a CAI).
Busket is offline   Reply With Quote
Old 02-21-2014, 11:24 PM   #11
wi111y
1995 SL
1995 SW2
I'll take a stab at that quick then, headliner isn't that hard to get out....
Currently installed in my '95, sorry
I believe so? Have to double check, but that's off already anyway.
Old 02-21-2014, 11:24 PM   #12
APAACARMMANN
APAACARMMANN is on a distinguished road
1997 SC2
power windows or manual?
APAACARMMANN is offline   Reply With Quote
Old 02-21-2014, 11:42 PM   #13
wi111y
1995 SL
1995 SW2
Manual everything, had AC, but only interior AC related parts are left.
Old 02-22-2014, 12:00 AM   #14
wi111y
1995 SL
1995 SW2
Update:
Plans changed, not scrapping this weekend...
Old 02-22-2014, 09:14 AM   #15
1badnotch
1badnotch is on a distinguished road
Does it have rear discs? I want to swap my '99 SL2 to rear discs. Let me know. Thanks. Mark
2006 Vue Redline,black,AWD,3.5 V6,Saturn all weather mats.
1badnotch is offline   Reply With Quote
Old 02-22-2014, 11:18 AM   #16
Spinnnerrr
Spinnnerrr is on a distinguished road
1993 SC1
My driver side window crank doesn't work anymore. Do you still have the parts inside the door for the window crank?
Thanks
Joe
Spinnnerrr is offline   Reply With Quote
Old 02-22-2014, 11:23 AM   #17
02OrangeSC2
02OrangeSC2 is on a distinguished road
02OrangeSC2's Avatar
2007 SKY Red Line
2004 ION Red Line
Sorry it's tan....
I need a tan top dash panel. Also cloth or leather?
The most Saturn's in Erie County Ohio
96 SL2 Gold
96 SC2 Red
02 SC2 Orange
04 ION RL GM Stage 2 Electric Blue
07 SKY RL GM Stage Kit Silver Graphite
10 SKY RL Black
02OrangeSC2 is offline   Reply With Quote
Old 02-22-2014, 11:50 AM   #18
wi111y
1995 SL
1995 SW2
Drums in the rear...
I have the window parts, can remove them..
Also have the dash pad.
Car is cloth.
What should I remove before scrapping car? minn505 S-Series Tech 13 01-22-2013 11:23 AM
Scrapping sound followed by a creak when braking nmsaty S-Series General 10 03-14-2007 02:05 PM
Grinding/Scrapping noise when braking BullyCanadian S-Series General 13 04-16-2006 09:34 PM
Metal Scrapping Sound...Drivers side firevswater5 S-Series General 1 03-09-2006 04:29 PM
scrapping noise Leilanic S-Series Tech 1 01-24-2003 10:50 PM
