#1 |
![]() Join Date: Sep 2013
I just picked up a '99 SL2,auto,silver ext,gray int,pdl,cc,rke with 105k on it for $2200. It is in pretty good shape. I have done a few things to it like new:t-stat,water pump,ects, flushed coolant,trans filter,trans fluid,ngk plugs,ntk o2 sensor. Mods:quad headlight mod,24/20 inch wipers,modified airbox. I got a ton of info from this site so far.
2006 Vue Redline,black,AWD,3.5 V6,Saturn all weather mats. |
#2 |
Nice! Your car will appreciate the attention
![]() What airbox mod did you do? Welcome aboard!
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#3 |
![]() Join Date: Jan 2012
1994 SW1
2000 SW2
Welcome to the forum and you get 2 brownie points ( non redeemable )
![]() Is this your first Saturn ? Keep an eye on things - especially oil and coolant, and the pavement where you park it.
97 sl2 a/t 104 K 1989 GMC 3500 454 129 K, 1969 442 455 rat rod |
#4 |
Thanks for the welcome. This is my first Saturn. I have been on here researching for about a month now. I found a lot of great info on these cars,which made things a lot easier. I have been keeping a close eye on the engine oil and coolant. It uses a small amount of oil,but not too bad.
As far as the airbox,I removed the resonator above the radiator,airbox inlet tube that is riveted in and cut out the corner of the airbox next to the battery. I am also going to get a K&N drop in filter soon.
#5 |
1994 SW1
2000 SW2
Synthetic oil generally will help to keep the oil usage from getting worse, if you can justify the extra cost and it is not burning a lot. It should also get you another 1-2 mpg.
Bookmarks |
