![]() ![]() Join Date: Jan 2013
2001 SL2
2004 VUE 3.5L
2001 saturn sl2
I was about the change spark plugs and do MMO treatment and when I removed spark plugs two of them No. 2 and 3 spark plugs threads have oil on it ... does it mean those two piston rings are shot? How much mystery oil we should add in each spark plug hole? What type of spark plugs you recommend? how about bosch 4501 which is platinum and iridium mix? Last edited by vikasevan; 12-21-2014 at 06:18 PM. |
![]() Join Date: Apr 2014
1993 SC2
What do you mean by oil on the plugs? On the threads? Or on the electrode? If it's on the threads it's most likely the valve cover gasket leaking.
$300 1993 SC2 finally plugging along with 184K and going up :) 38 mpg! 1993 Foxbody build in slow progress |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010
ALWAYS USE NGK COPPER SPARK PLUGS ONLY.
Our sattys use a waste spark system (fires 2x) so it will EAT up any other plug and not give the performance you might expect. |
#4 | |
![]() Join Date: Feb 2011
1995 SL
1995 SW2
Common enough problem, the gaskets around the spark plug seals aren't sealing properly. If it's not enough to work it's way into the chamber and foul the plugs, fixing it is optional. My brother's car never would seal right in that area, and it didn't cause any issues.
'95 SL 5 Speed 220k - DD '95 SW2 5 Speed 230k - Gone! '95 Camaro Z28 - Project '00 Tahoe Z71 - Truck stuff |
#5 |
![]() Join Date: Jan 2012
1994 SW1
2000 SW2
The cam cover is leaking into the spark plug wells, and if enough oil leaks into the well, it can affect spark plug performance. You should think about replacing the cam cover gasket. Do not use the the Bosch plugs. NGK BKR5ESA-11 are the best bet.
97 sl2 a/t 104 K 1989 GMC 3500 454 129 K, 1969 442 455 rat rod |
Tags |
mmo soak, spark plug replacement |
Considering replacing spark plugs and spark plug wires - Need advice | 2002SaturnMan | S-Series Tech | 25 | 10-15-2015 08:29 AM |
Dealer pricing on spark plug wires and spark plugs. | KeithR | S-Series General | 25 | 05-20-2011 12:52 AM |
1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires) | onixwj | S-Series Tech | 12 | 12-11-2009 09:07 PM |
Spark Plugs | mako462 | Vue Tech | 5 | 10-01-2006 11:30 AM |
Changed spark plugs and wires, look at old plugs (pics) | Chingon | S-Series General | 12 | 03-30-2005 03:42 AM |
