Old 08-10-2020, 09:48 PM   #1
td1238
td1238 will become famous soon enoughtd1238 will become famous soon enough
Default Original Metal Exhaust Manifold Gasket
Curious to know how many others reuse the metal compression gasket for the exhaust manifold. Mine is original to the car, and has 360,000 miles on it. It has seen an engine rebuild at 219K, and a head gasket replacement just a few months ago. Considering its track record, I wouldn't dream of replacing it with a fibrous gasket.
T
td1238 is offline   Reply With Quote
Old 08-11-2020, 09:27 AM   #2
BV22
2002 SC1
Default Re: Original Metal Exhaust Manifold Gasket
I pulled my exhaust manifold either 3 or 4 times (can't recall exactly) to clean air passages to get rid of the dreaded P0410 code. Reused the original gasket each time with no problems. I did always tighten the manifold bolts in a consistent pattern and avoided overtightening.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Old 08-11-2020, 10:04 AM   #3
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
I'm pretty sure I got a new metal gasket in my rebuild kit.
Old 08-11-2020, 07:42 PM   #4
quickster
quickster is on a distinguished road
At 286,000 miles, i just replaced my exhaust manifold/pre-cat, and re-used the original metal gasket. The gasket they sent with the new manifold covered the small holes in the head, so i elected not to use it. I've had no issues.
2002 SL2, Bought new in October of 2001, Now has 281,300 miles
quickster is offline   Reply With Quote
Old 08-11-2020, 08:12 PM   #5
td1238
Funny that you mention that. My friend's '01 SL2 has clogged passages, but doesn't throw the code. Did compressor work, and in the process noticed that the air pump line was clogged, so unclogged that, but also noticed that the manifold passages were clogged, and had had enough for the night, so they haven't been unclogged yet. Guess he's lucky, though he always has some other code.
exhaust manifold gasket yveshotrod Astra Tech 2 11-25-2018 02:38 PM
'93 SW2 Exhaust Manifold Gasket - did I get the right one? carlbo S-Series Tech 1 09-03-2012 10:52 PM
Exhaust Manifold/Head Gasket TomM96 S-Series Tech 2 11-07-2008 04:20 PM
Exhaust Manifold Gasket R & R MickSaturn S-Series Tech 24 01-26-2007 01:57 PM
Exhaust manifold gasket! thewretched S-Series Tech 4 09-30-2006 06:57 PM
