Old 08-09-2020, 09:09 AM   #1
amgarb
amgarb is on a distinguished road
Default negative fuel trims
This is the '98 DOHC that I recently replaced the head gasket on. I've been driving it some but has a lack of power; especially at low rpms in high gear. Like at 45-50mph, it can hardly maintain speed without downshifting.
Finally put my OBD2 scanner on it Friday evening. Fuel trims were way negative. During slow idle, ST at -2% and LT at -14%. Raised rpms to 2500 and ST went to -28% and LT at-10%.
Unplugged front oxygen sensor and battery. Let car sit overnight.
Took short drive this morning. Since oxygen sensor was unplugged, it stayed in open loop mode and the fuel trims both stayed at zero. Power was restored and seemed normal.
I do have a P0440 Evap code but I believe this is because the nipple on the purge valve where the fuel line connects is broken off. I discovered this during the head gasket reinstall but didn't fix it because I wanted to make sure the car would run first. I did order a new valve from Rock Auto yesterday but doubtful this will fix it. I think if the purge valve started sucking unmetered ambient air it would actually cause the fuel trims to go positive, not negative.
Thoughts?
amgarb is offline   Reply With Quote
Old 08-09-2020, 09:32 AM   #2
bumpdraft
bumpdraft's Avatar
1998 SW2
Default Re: negative fuel trims
Purge Valve:
When the purge valve stuck open on my ‘98 DOHC, the warmed-up engine wouldn’t start without flooring the gas pedal for total fuel cut-off. After shutting off the engine, there was a strong smell of gasoline vapors from under the hood. Fuel vapors were wafting out of the air filter box.
I do not recall ANY codes or warning lights being set when the purge valve stuck open.
Last edited by bumpdraft; 08-09-2020 at 09:38 AM. Reason: No MIL for the purge valve stuck open
Fuel trims questions Anjey Aura General 11 03-11-2019 06:51 PM
Saturn SL running rich, fuel trims VicSaturnS S-Series Tech 12 12-07-2017 01:12 AM
Running rich fuel trims to -40 97sl2DOHCaut1.9 S-Series Tech 29 10-31-2015 12:54 AM
Running Out Of Gas, Resetting Fuel Trims td1238 S-Series Tech 1 05-25-2012 05:36 AM
fuel trims racinginblood S-Series Tech 5 04-28-2012 08:19 AM
