Old 02-06-2018, 08:31 PM   #1
oldmanina2005vu
oldmanina2005vu will become famous soon enough
2004 VUE 2.2L
2008 SKY Red Line
Default Transmission Swap No Start
I just completed my latest VTI to AF23 transmission swap in a 2003 2.2L Vue yesterday. I followed Jimmy Ford's manual as I have in the past. After hooking up all the electrical connections and topping of the fluids I tried to start the car. The first thing I noticed was that the Service/wrench and Service Engine Soon Light was illuminated, the low fuel light was also illuminated even though I know there is at least 1/4 tank. I could not hear the fuel pump running and there is no pressure in the fuel rail. There is no security light on so I don't think the passlock is a problem. When I turn the key on the security light comes on for a few seconds and then goes out.
The engine ran before I started the swap. Any ideas what direction to start looking? There are no blown fuses and I tried swapping out the relays but no luck there. Oh no codes on my scanner.
oldmanina2005vu is offline   Reply With Quote
Old 02-06-2018, 11:20 PM   #2
Bruce in Montan
Bruce in Montan is on a distinguished road
Default Re: Transmission Swap No Start
While I don't pretend to know what I'm talking about....if you don't hear the fuel pump and you don't have any pressure at the rail...maybe check the wiring close to the tank for voltage. While it would be odd for the pump to go south at the same time that you're changing transmissions, a wire could have been pinched.
Bruce in Montan is offline   Reply With Quote
Old 02-07-2018, 11:17 AM   #3
Judogi
Judogi is on a distinguished road
2001 SC1
Where's this manual you speak of? I found several threads on different swaps, but no PDFs or anything. Thanks!
Judogi is offline   Reply With Quote
Old 02-07-2018, 05:43 PM   #4
waiter21
2003 VUE 2.2L
My experience is with a VTI to manual swap..
Any codes set on the ECM??
Did you swap ECMs? On my VTI to Manual swap, the ECM had to be swapped to support the manual tranny. (different ECM program for a automatic vs a manual tranny)
There is a ground wire on the ECM, is it installed?
Not sure about fuse box.... did you use the original wire harness or the harness from the new tranny? (there is a difference in the harnesses between the VTI and the manual. also difference on the fuse box, I seem to remember there was something about fuel pump relay. (I NEED TO CHECK THIS)
http://www.saturnfans.com/forums/sho...d.php?t=215544
The electrical plugs for the throttle body and the fuel injection can be accidentally swapped. Scroll down to post #16
http://www.saturnfans.com/forums/sho...d.php?t=215542
Old 02-07-2018, 05:44 PM   #5
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
Default Re: Transmission Swap No Start Problem Solved
Not sure exactly what happened but here is what I did to get it running today.
1. I discovered the ECM/TCM fuse was in fact blown. It must have happened after I checked them and was playing around trying to get it running. There appeared to be a direct ground on the output side of the fuse. I chased the two wires that are on that fuse and discovered that the one going to the ECM was the culprit. It seemed as though there was a short in the ECM itself. It worked fine before I started the swap. I disconnected the battery before I took the connectors off.
2. I just happened to have a spare ECM laying around from a previous 2003 VUE and I swapped it out for the one in the Vue. After I reconnected everything there was no short and the fuse was good.
3. I rechecked all my wiring which was a PIA since I had already put it in the looms. Everything was wired properly.
4. I turned the key on and up came the security light, Service/Wrench light, and the service engine soon light. This time the gauges were working however.
5. I did the 30 min. Passlock reset and she fired right up.
It must have been the ECM all along. I am not sure how this replacement will work since it is not the one that came in the car.
TO JODOGI, if you PM me an email address I will send you the manual. It is a quite large PDF. Also if you have any questions don't hesitate to message me.
Old 02-07-2018, 05:47 PM   #6
waiter21
2003 VUE 2.2L
Glad to see you got it running...
I bypassed my passlock with a resistor. Works great when I use a remote starter.
http://www.saturnfans.com/forums/sho...d.php?t=215634
NOTE - If you connect the throttle body and the fuel injector plugs worg, it will toast the ECM.. This normally isn't a problem from the factory as the wire looms are tied up so it almost imposible to do this. but on a engine swap, its easy to do.
Thats what was wrong with my Vue. We call it a "Rescue Vue". The PO did a good job of doing the sswap abut could never get it running so it sat in their drive for 6 years. I offered then a couple hundred dollars for it and had it running in a few days with a used ECM I bought from ebay...
Old 02-07-2018, 05:48 PM   #7
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
Default Thanks for your help!!
waiter21, Thanks for your suggestions but as stated in the previous post I found the problem. I appreciate you taking the time to respond. I value your input and read any posts that I see with your name. I always learn something.
Old 02-07-2018, 05:51 PM   #8
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
Default Passlock Bypass
My next chore is to install a remote start and keyless entry system. I used your advice from another post on how to install the resistor. I have one out in the garage with the remote start system. The car did not come with any key fobs so I guess if anyone is stupid enough to steal it they can have it.
Old 02-07-2018, 05:55 PM   #9
waiter21
2003 VUE 2.2L
There are a lot of Vues with trashed VTIs.. It sounds like an Af23 swap might be an interesting winter project..
I'll send you a PM if you'll send me the manual also. I'm interested to see what all needs to be done..
Again, glad to hear you got it running... We really like ours and tow it behind the motorhome.
Old 02-07-2018, 06:12 PM   #10
Judogi
2001 SC1
PM Sent! Thank you!
Old 02-07-2018, 06:21 PM   #11
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
I've saved four great little SUV's from the junk yard with this manual. I don't know who Jimmie Ford was but he sure did a bang-up job on that manual.
Old 02-09-2018, 12:04 PM   #12
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
Ok I got it running but not so good. After clearing codes I ran the car for several minutes and got it up to 3000 RPM a couple of times while sitting. Didn't seem to be any misfiring or sputtering. After the car reached operating temperature of approximately 185 F. the car started sputtering and after checking codes I found three pending codes.
P0171 Fuel Trim System Lean Bank 1
C206F no description but chassis related
P0101 Mass airflow sensor performance
If I clear the codes and let the car sit until it cools down it will again run fine until it reaches temperature.
Any idea where to begin looking? Could it be a vacuum leak somewhere? I put in all new intake manifold seals, cleaned injectors new spark plugs, and air filter. Is it possible the Mass airflow sensor is bad? Maybe a ground problem? I'm stumped at this time. I put in a new fuel filter too.
Old 02-09-2018, 12:23 PM   #13
waiter21
2003 VUE 2.2L
P0171 - Did you install new o-rings on the intake manifold... (I think you said you did) Mine were crushed flat and had vacuum leaks that were causing the 171 trim.. Look at post #7.. Don't forget to clean the PVC orifice while you have the manifold off.. A cracked or damaged manifold will also cause this..
http://www.saturnfans.com/forums/sho...d.php?t=217319
P0101 - You don't have a MAF sensor, you have a MAP sensor (Manifold Absolute Pressure). Not sure how the 101 is getting set????
Anyway, if you are able to read the raw data, your MAP sensor should read atmospheric pressure when the engine is OFF.. Mine was reading 15.1psi when it should have been 14.7 psi. This will screw up the fuel air mixture. I replaced the MAP sensor and this solved my P-106 problem..
Scroll down to post #46
http://www.saturnfans.com/forums/sho...=215542&page=3
Rough running could also be grounding problems. I added several ground straps and this solved some problems I was having with speedometer (speed sensor) and hesitation.
http://www.saturnfans.com/forums/sho...d.php?t=216101
Old 02-09-2018, 12:51 PM   #14
waiter21
2003 VUE 2.2L
I didn't get the manual. Can you send it to me at
waiter@iflyez.com
Tnks
Old 02-09-2018, 11:16 PM   #15
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
Waiter21, check your spam mail. I sent it again. Thanks
Old 02-10-2018, 11:08 AM   #16
waiter21
2003 VUE 2.2L
Got it. Tnks
Old 02-10-2018, 06:19 PM   #17
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
Default Still fighting P0171 code and rough engine
I took all the components off for the intake system and reassembled them carefully to make sure everything was seated properly and all O-rings were in good shape even though they are new. I verified that the brake booster hose and all other connections were secured. I put a wrench on the ground bolt at the back of the engine where the ground cable and the ground wires for the engine attach. It was snug but torqued it down just a hair. After reconnecting the battery and turning the key to the ON position but not starting I cleared all existing codes. When I turned the key to the OFF position and then turned it back to ON. The REDUCED POWER and Service/wrench light came on. WHAT!!
I immediately went back under the hood and removed and cleaned the dickens out of the ground cables and reinstalled. I cleared codes again and she fired right up. I thought I had found the problem until after about 10 min. of running the engine it began to sputter when i gave it gas. I checked for codes and found the P0171 code had come up. I also noticed the high speed fan comes on immediately with the code. I cleared the code again and started the car. It runs fine until the code pops and the fan comes on high.
Can this be a O2 sensor problem? Will a fault O2 sensor or a clogged converter cause this code? I know what a badly clogged converter sounds like and do not hear anything out of the ordinary there also is a fair amount of condensation coming out the tail pipe. Any help would be appreciated. Oh so far the only code I have is the P0171 but it runs so terrible I haven't run it much.
Old 02-10-2018, 08:10 PM   #18
pierrot
pierrot's Avatar
Default Re: Still fighting P0171 code and rough engine
oldmanina2005vu, you've been doing yeoman's work to try and correct this problem and you have my admiration! According to my FSM, P0171 is defined as "Fuel Trim System Lean" just as you've noted previously. It sets after two cycles where the PCM discovers this error and cannot make its adjustments to bring the fuel trim back into the normal parameters.
Possible causes: vacuum leak; low fuel pressure; poor fuel quality or water in the fuel; exhaust manifold gasket leak or leak arouind O2S-1 (in ex. manifold); fuel injectors clogged; O2S-1 weak.
Considering a comment made in post #1, the fuel pump's condition (if sub-normal) may be contributing to this lean fuel trim problem. A weakened fuel pump can result in reduced fuel pressure.
347K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. I fear that I will be correct. I'd rather be wrong.
Old 02-10-2018, 09:25 PM   #19
waiter21
2003 VUE 2.2L
MAP sensor... If I remember right, its tucked uo under/beside the throttle body..
Can you look at sensor sats with your scanner??
Old 02-11-2018, 11:06 AM   #20
oldmanina2005vu
2004 VUE 2.2L
2008 SKY Red Line
This morning I hooked up my scanner and TorquePro for Android. I took a reading of the static Manifold Air Pressure which was 14.35 PSI. I figured this was a good reading. I then cleared the P0171 pending code and set a graph for the two O2 sensors and started the graph. The Bank 1 upstream sensor was swinging between .2 and .8 volts and the Bank 2 downstream was holding up near the .8 volt line and fluctuating somewhat. I let the car heat up and when it got to the 195 F temp the Bank 1 sensor had a low spike of .0 and soon after that the P0171 code set and the cooling fan came on. The readings for Bank 1 then were in the .4 to .2 range with no spikes above .4 and the Bank 2 readings jumped up above the .8 line and creeping up to .9 volts.
I believe it is either a bad O2 sensor or something that triggers when the car gets to the 195 F. point. When does the off line cycle to on line fuel trim control begin? What triggers it? Is it time related or temp related?
Engine Swap - No Start buckeye joe Vue Tech 28 12-23-2013 01:03 AM
05 2.2 Motor swap, now no start. please help! fitztool Vue Tech 32 10-10-2012 12:08 AM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
MP2 swap now no start itsnotme1988 S-Series Tech 5 10-20-2010 09:26 PM
96 to 98 swap now no start... travistuttle S-Series Tech 14 01-02-2008 05:56 PM
