Old 04-15-2007, 12:48 PM   #1
05ion29
05ion29 is on a distinguished road
05ion29's Avatar
Question No current?
Hi, I have a 05 ion 2 qc. that I picked up as salvage (storm damage) and I have had the car now 4 months no problems other then the cigerate lighter haveing no power. Nothing works when I plug something into it? Also when I got he car the horn was not working. I replaced the horn and in the middle of a very furious beep it cut out. I've check all my fuses they are all ok. Any ideas? ty.
-mike-
2005 Silver Auto Ion
05ion29 is offline   Reply With Quote
Old 04-15-2007, 04:34 PM   #2
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
Default Re: No current?
-mike-
both boxes for fuses under the hood and under the center console near the gas peddle??
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
06_Ion2 is offline   Reply With Quote
Old 04-15-2007, 10:42 PM   #3
05ion29
05ion29's Avatar
Yep both boxes
Old 04-16-2007, 08:36 AM   #4
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
-mike-
You might have broken a piece in the steering column that makes contact with another piece to activate the horn, if it's set up like a previous car I once owned. I popped off the cover over the steering column to see it, but this was before air bags in the column, so it may be more difficult to get at, if that's the problem.
daver is offline   Reply With Quote
Old 04-16-2007, 08:39 AM   #5
tlg
tlg is on a distinguished road
tlg's Avatar
2006 ION-3 Quad Coupe
Trace the wire back from the cig lighter to .... well to however far back you can. Cut back some insulation and use a volt meter to see if you have power (remember to tape up the cut afterwards).
If you do have power, then you have a short somewhere between there and the cig lighter. If you don't, then keep tracing the wire back until you find power.
When you do have power, you can trace forward till you find the short.
Or do the easy method and splice in a bypass wire from power to the cig lighter.
Or do the really easy method, and just splice a bypass wire from the fuse to the cig lighter.
2006 Ion Quad Coupe 2.4 5sp manual
tlg is offline   Reply With Quote
Old 04-16-2007, 11:12 PM   #6
05ion29
05ion29's Avatar
ok lol, ty
let ya no how it goes
which current crystal scan General Saturn Discussion 2 09-20-2009 08:15 PM
Current Owners.... ksl Outlook General 27 03-29-2007 07:57 AM
What are the current incentives? jmatero Vue General 7 06-06-2004 03:24 PM
What is the current % on GM Discount? 04AWDV6VUE General Saturn Discussion 4 05-20-2004 10:33 PM
Current L no-go for '06 LSLWSupplier L-Series General 35 10-27-2003 11:11 AM
