Old 01-26-2007, 04:58 AM   #1
cfg83
cfg83 is on a distinguished road
cfg83's Avatar
Default Tapping Valves or Timing Chain or ?!?!?!?!?
Hello -
(I drive a 1999 SW2, manual tranny)
I am getting a tapping sound that reaches the passenger compartment. At first I thought it was tapping valves because that's what the Saturn dealer said. Then I thought it was the Timing Chain because it shows up at idle and goes away when I get my RPMs up, and appears to be coming from the front passenger side of the engine.
Sooooooo, I bought a car stethoscope and have been trying to locate the rattle. I have been putting it on the engine cover and I don't hear the tapping sound. I put it where the Timing Chain is located and don't hear the tapping sound. I put it farther down the side of the engine on the Timing Chain side, near the drive belt, and I still don't hear the tapping.
Where I do hear the tapping is when I put the stethoscope on the frame of the car. This makes me think that it is just a "loose plate" somewhere in the engine bay. Orrrrrr, the frame, in some magic way, is isolating some internal engine sound that I can't hear over the other engine sounds and is transmitting it into the passenger compartment.
I finally got a clean recording of the sound (it's duller in the passenger compartment) :
http://home.earthlink.net/~cfg83/sat...ng_me_nuts.wav
I put the stethoscope on the frame part that has the "Saturn Power Module" sticker. I then put the recording microphone up to one of the stethoscope earbuds and isolated it with a rubber grommet cover, which kept the engine noise from overcoming the tapping noise. As I was recording, I pushed on the throttle body. You will hear the ticking noise momentarily subside and then come right back.
It's not always this bad, but it's more prevalent in the cold. These days it's slowly getting worse. It's like the Saturn version of Chinese Water Torture !!!!!!
What do your well-trained Saturn ears think?
Thanks!
CarloSW2
cfg83 is offline   Reply With Quote
Old 01-26-2007, 06:28 AM   #2
Sir Trews
Sir Trews is on a distinguished road
Sir Trews's Avatar
Default Re: Tapping Valves or Timing Chain or ?!?!?!?!?
Besides hearing the rest of the drivechain running... you say it sounds like it's coming from the passenger side of the frame? Considering what I hear in that recording you made (listened to it several times over)you might need to look a little lower. Bearings are running (most of what is heard) but a rattle down low on the passenger side? Could be several things.. alternator, to start with. Gotta remember that everyting runs on that side on these. You leaking fluids? Steering feel ok? Could be any one of those.
Take or leave it as you will... but I would have to say one of the accesories would be the sound, hence the 'transmitted' sound to the frame. Oh! And speaking of that... don't forget the tensioner for the belt... that one just loves to make noise!
Don't know if this helped.. I hope it might have.
<=== Just a Hotrod... with good ponies!
My SL2..She's hurtin'. Pretty bad. No pic.
All GM stable here... '71, and '89, both long beds...
*Hugs* Saturn Maniac! Glad you're still here! ;*)
Sir Trews is offline   Reply With Quote
Old 01-26-2007, 08:13 AM   #3
eljefino
eljefino's Avatar
1995 SW1
Listen to this and see if it confuses you more
http://smg.photobucket.com/albums/v1...attlechain.flv
Valves should only tap when the lifters bleed down because:
-- the car hasn't been run in months
-- the car is 3 quarts low on oil
Old 01-26-2007, 08:14 AM   #4
BarnOwl
BarnOwl's Avatar
Take off the serpentine belt and run it briefly, just long enough to establish whether the sound is there without the belt. If it's not then, you know it's a belt driven device. Tensioners and idler pulleys are the usual suspects but, it could be any belt driven device.
Old 01-26-2007, 03:25 PM   #5
cfg83
cfg83's Avatar
Hello -
GOT IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It was a loose headlight (adjustment?) bolt on the front passenger side :
http://www.saturnfans.com/photos/sho...hp?photo=34279
Sir Trews -
I did what you said to make sure it wasn't one of the pulleys. I was betting it was the tensioner pulley but it wasn't.
eljefino -
I was trolling to find the solution to this problem last week and had already listened to this sound. It was close, but not quite right.
BarnOwl -
If I hadn't found it, I was going to remove the serpentine belt next.
The key was the stethoscope. I learned from all you saturnfans that this is invaluable and you're right. You can't isolate the source of a noise without it (too much ambient engine noise in the way).
This has been bugging me for over a YEAR!!!!!!!!!!!!!!!! Tappy valves, timing chains, loose pulleys!?!?!?!?!?!!?!?
FINALLY!!!!
(a 3 smile success story)
CarloSW2
Old 01-26-2007, 04:14 PM   #6
eljefino
eljefino's Avatar
1995 SW1
That's funny, I had the same headlight loosen up on my 98 (same style). I take it you turned it so the bottom of the headlight is 1/4 inch from the top of the bumper cover? I always thought 2nd gen saturns had the worst headlights but it could be their aim has shifted. My 98 now aims great.
My cutlass ciera used to make a "teeth chattering" noise when it was cold, turns out the front license plate was vibrating at a harmonic frequency when the thing idled.
Old 01-26-2007, 05:03 PM   #7
Titanium48
Titanium48 is on a distinguished road
How about a few seconds of ticking when a saturn that is not low on oil is first started after sitting overnight? I always figured that was normal.
Titanium48 is offline   Reply With Quote
Old 01-26-2007, 05:18 PM   #8
cfg83
cfg83's Avatar
eljefino -
Right now I have just ziptied the screw to keep it from moving. I am going to adjust it tomorrow at my non-Saturn mechanic. This thing has been the "impending doom" for me for a long time. The timing chain was the closest description to the problem that I could find on saturnfans, but the stethoscope ruled that out. All I could hear from the timing chain was a swishing sound, so I figure that is the oil sloshing around. I switched to heavy dino oil to try to get rid of the sound (125K miles on this car). Now I am going to slowly switch back to lighter oil for MPG reasons.
The "tappy valves" was originally the prognosis of the Saturn techs (of the now defunct Saturn of Monrovia). They said I had run my oil low. This is possible because I had recently switched from a "normal" 15+ mile street commute to a 35+ mile freeway commute, so I was being harder on the engine.
I didn't want to post until I had the clean recording. That took about 3 or 4 recordings until I could hear a clean tap and figure out how to isolate the sound. You don't know how many times I have pulled into parking lots, popped the trunk with the engine running, and used my "Dr. Kilder" car stethoscope. I should have gotten a white doctor's coat and a car-sized tongue depressor and asked the car to say "Ahhhh".
Harmonic frequency is right!
Thanks Again,
CarloSW2
Last edited by cfg83; 01-26-2007 at 05:20 PM. Reason: better description of the timing chain sound.
Old 01-26-2007, 05:24 PM   #9
cfg83
cfg83's Avatar
Titanium48 -
That is one of the things that misled me. Sometimes the tapping sound would "go away" on it's own. I would notice it alot when the engine was stone cold, but I think it finally got loose enough so that I could hear it all the time and isolate it better. If I had the stethoscope from the start, I would have found the problem a long time ago.
I think I do have the "early ticking" when it is really cold, so that made things more confusing.
CarloSW2
Old 01-26-2007, 05:27 PM   #10
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
haha glad you found the problem. I just found this thread and was going to say its NOT the timing chain at all. If its only at idle, its not the timing chain because it would growl at ANY engine speed
and LOL at the car-sized air-dam compressor
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
andy_95sl2 is offline   Reply With Quote
Old 01-26-2007, 11:36 PM   #11
Rayman86
Rayman86 is on a distinguished road
1999 SL1
Yeah I have the same problem on my 99. Apparently its a spring in the adjusters or something like that. A lot of Saturns come in to my work with that problem on the passenger side with the headlights. Mine is so bad that you can see the light shaking when youre parked in front of a reflective surface.
Rayman86 is offline   Reply With Quote
Old 01-27-2007, 03:09 AM   #12
Those shaky lights are WICKED annoying to oncoming drivers (to the point of being a hazard). Good thing you nailed it, cfg.
Old 01-27-2007, 10:30 PM   #13
sPuddingTime
sPuddingTime is on a distinguished road
1993 SL2
lol, you say "wicked" in WI too? I thought it was a Boston thing. sorry to see this is more widespread that I thought.
gotta go take a wicked pissa
93 SL2 107k mi
sPuddingTime is offline   Reply With Quote
Old 01-27-2007, 10:51 PM   #14
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Hay............what about...................."bang a U-ie"
Old 02-20-2007, 11:46 AM   #15
fed_up
fed_up is on a distinguished road
so all in all u guys mean to tell me its the Headlights that are making that sound...b/c i got the same thing happin..
fed_up is offline   Reply With Quote
Old 02-20-2007, 12:01 PM   #16
BarnOwl
BarnOwl's Avatar
There are lots of things that can tick or tap on a car. If it's only at start up, a cheap oil filter comes to mind. Timing chain, rod bearings, lifters, just about any belt driven device, loose lots of things, etc. can all make a tapping sound. You just have to isolate it.
Old 03-04-2007, 01:49 PM   #17
NVMY03GT
NVMY03GT is on a distinguished road
ARGH!! I think I have the same problem - Did yours by chance do it EVER while in park or only in Reverse and Drive? Did it sound like Metal on Metal?
Be nice to me - Im still Learning
2003 Saturn Ion 3
NVMY03GT is offline   Reply With Quote
does broken timing chain damage valves? schreckman S-Series Tech 8 05-12-2009 10:30 AM
timing chain tapping? Rusty S-Series Tech 5 08-02-2007 06:21 AM
stalling problem after replacing timing chain, valves ls1racer ws6 S-Series General 4 02-19-2006 05:50 PM
stalling problem after replacing timing chain, valves ls1racer ws6 S-Series Tech 0 02-19-2006 04:23 AM
Timing chain/ valves mozart3851 S-Series Tech 10 08-18-2005 11:21 PM
