Old 10-09-2006, 09:16 PM   #1
anasazi
anasazi is on a distinguished road
1992 SL1
Default clicking coming from rear drum brake
what might cause a clicking noise from a drum brake? it only occurs when the brakes are in use and it varies with speed.
anasazi is offline   Reply With Quote
Old 10-09-2006, 10:04 PM   #2
WingsOfSaturn
WingsOfSaturn's Avatar
Default Re: clicking coming from rear drum brake
All kinds of springs/bars/shoes could be causing it. Only way to find out is to open them up.
Is it only from one side? Open up both and compare everything.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 10-09-2006, 10:11 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
worn linings? when is the last time you inspected or replaced the rear brake linings (shoes)?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Rear drum brake job crosaturn S-Series Tech 18 11-23-2009 12:11 AM
No Start, clicking coming from the rear of the Car. TobyMcToberson S-Series Tech 7 09-26-2008 11:35 AM
Rear Brake Drum Question. 06 Ionised Ion General 5 11-16-2007 05:46 PM
Rear Brake Drum Noise hipster35 S-Series Tech 5 02-22-2007 08:51 AM
Rear drum brake conversion ebristol Ion Tech 1 01-02-2007 03:17 PM
