Old 02-02-2020, 02:11 AM   #1
molleh
molleh is on a distinguished road
Default Sudden sharp pull to right around curves/turns
I have a 99 SL with 290k on it and for the past few hundred miles it's started doing this thing where when you start going around a right hand curve, like a freeway on ramp where you're in a steady turn at 35+ mph, the car will jerk to the right once you turn the steering wheel past 10 or 15 degrees.
It feels like the right front wheel is suddenly turned (or camber changes or something) and it pretty violently pulls to the right. Once I straighten the steering back out it sort of pops back to how it should be in the opposite fashion (once you get past 10-15 degrees, suddenly you're going straight-er than you expected.)
Tomorrow morning I'll be getting her up in the air to take a look at the suspension stuffs but I figured I'd check if there's a known common failure point I can check, that causes this type of thing. Thanks!
molleh is offline   Reply With Quote
Old 02-02-2020, 03:40 AM   #2
454cid
Default Re: Sudden sharp pull to right around curves/turns
No experience with this, but I think you're on the right track with physically taking a look at the suspension and steering components. It sounds like something's worn out to the point of being loose/shifting under a side load. You definitely need to figure this out before it moves from shifting to disconnecting!
I wonder if it could be your subframe getting rusty enough to not hold the control arm in place. well enough.. probably on the left in this case.
1999 Chevy K3500
Old 02-02-2020, 08:08 AM   #3
trottida
trottida's Avatar
When my SW2 did this it was the tie rod end that was worn.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 02-03-2020, 10:05 AM   #4
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
If the steering components are tight it could be the steering rack is worn out and jumping a tooth.
Old 02-06-2020, 10:07 PM   #5
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
Mine was doing this exact thing 3 years ago - very disconcerting. I think it was the LCA on the passenger side that was changed. I'll check my records to verify
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Old 02-06-2020, 10:54 PM   #6
BV22
2002 SC1
Badly worn ball joints on a non-Saturn vehicle had a similar effect for me. Had to turn in the direction of the turn at the beginning, and then turn the other way to continue in the turn direction planned.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Hesitation on sharp left turns Porterdavid Ion General 2 09-15-2016 05:19 AM
veering in curves at speed isotopeman S-Series Tech 13 12-16-2012 04:34 PM
What causes a loud creak/groan from front suspension on slow sharp turns? cheapybob S-Series Tech 13 10-19-2011 11:33 PM
Pull Cylinder Head in Car or Pull Motor First? Rum Runner S-Series General 22 03-09-2010 02:05 PM
Engine stumbles on sharp turns? Green92SL2 S-Series Tech 11 06-13-2007 03:02 PM
