Old 06-18-2019, 08:37 PM   #1
LW200 fan
LW200 fan is on a distinguished road
Question LW liftgate latch not working.
Hello
03 LW200 with 234K and still running well.
My liftgate latch started not latching and locking the gate this past winter. The problem came and went a few times and now will not latch on the striker at all. I Oiled the latch and there is no visable damage to latch and hook. I would appreciate repair tips. Thanks
LW200 fan is offline   Reply With Quote
Old 06-19-2019, 03:48 PM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: LW liftgate latch not working.
Welcome to the forum!
Does your remote release the lift gate latch when you operate the remote?
When you push the driver's door lock/unlock button several times does that release the latch?
The striker can be adjusted with the proper size torx socket if there is a mis- alignment here.
In short, explain in much further detail the issues you are having. If it really will not latch, how are you keeping the lift gate closed? The gas struts will raise the liftgate unless they are worn out.
We'll figure it out and get this taken care of.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Old 07-13-2019, 07:05 AM   #3
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
Looks like we lost the OP, but I have a related question. Can these locks be fixed. My Bride's 03LW had the same problem. I did find one. ( Reasonable money because car was mismarked as an Astra? at yard & key was missing), But the glut of parts has ceased for these cars.
Tom Walsh is offline   Reply With Quote
Old 07-13-2019, 11:48 AM   #4
rb6667
rb6667's Avatar
^^ It is doubtful that the lock can be repaired. I ran into one in a JY one day. Did not realize that is was damaged before I pulled it. Looked like the internal main shaft just sheared off.
The JY lock you got should work just fine assuming your actuator still functions. Just won't be able to use a key since you did not get one.
I always pull the whole tailgate lock assembly when I find a wagon with keys.
Agreed that parts for these cars are not easy to find now. Especially the wagons!
Old 07-16-2019, 10:53 PM   #5
Tom Walsh
Good point, I never thought about keys. Door unlock at door switch and clicker work. Would be nice if we could get gm to loosen up about key codes. I could get the VIN, but I seldom have any luck with them with out a title.
Old 07-16-2019, 11:03 PM   #6
Tom Walsh
What am I thinking. the key goes into the keylock assembly. The latch is separate. It operates with a braided wire like a bycicle brake. My key doesn't match anyway cause I already changed the lock assy.
Old 07-17-2019, 08:18 AM   #7
rb6667
rb6667's Avatar
^^ It takes a personal relationship with someone at the dealer to get a key cut from a VIN. Someone who knows you well and can vouch for you that you are not a thief. Do you know someone like that? Sales Staff, Service Staff?
Old 07-18-2019, 09:39 AM   #8
Tom Walsh
I've got one but they seldom can go past the dealership rules. I'm in asking stupid questions about Saturns all the time. They say "not you again". Even if they had any parts for them, I couldn't afford their prices. Every once in a while they will weaken. It would be nice just to know you can just get a key. I can't say " Who would steal a Saturn" , cause I had one stolen. They had my tenants move their cars so they could steal it? At least I hadn't started working on it.
Old 08-10-2019, 08:57 AM   #9
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default Re: LW liftgate latch not working. old key trick
hi sages- going to a local locksmith is often successful. they can cut a new key if you can take out and show them the key lock cylinder. many have the cylinder pins or needles of various sizes to do this . you might be clipped but not as badly as at a dealer. good luck bob f
rfisher is offline   Reply With Quote
When your SW2 liftgate doesn't latch.... hholbein S-Series Tech 11 02-10-2017 11:43 PM
Liftgate lock not working twodogs755 General Saturn Discussion 0 09-14-2010 03:29 PM
97 SW2 liftgate latch source? postmortal1 S-Series Tech 3 08-15-2009 08:17 PM
Rear liftgate latch on a Gen 2 SW2 hholbein S-Series Tech 0 04-24-2009 02:20 AM
liftgate latch adjustment 95 SW2 cognomen62 S-Series Tech 10 03-07-2009 01:57 AM
