Old 12-25-2018, 08:31 PM   #1
menusetc
menusetc is on a distinguished road
Dizzy wheel cylinder
I've recently purchased a 2000 LS1 for commuting purposes and am replacing brakes. Bad wheel cylinder and although normally simple job, i'm having issues. I see a single mounting bolt and brake line. Assuming the brake line is 10mm, the mounting bolt however im not sure of and the wonderful engineers at saturn decided the placement would be ideal in a location thats impossible. Any suggestions on tool choice and tips to remove the bolt. Thanks in advance, Wayne
menusetc is offline   Reply With Quote
Old 12-26-2018, 02:09 PM   #2
Al10453
Al10453 is on a distinguished road
Default Re: wheel cylinder
I think there was a thread about this before on this site. If I remember right someone said to a cranked wrench, didn't work for me but a long skinny open end wrench did.
Al10453 is offline   Reply With Quote
Old 12-29-2018, 12:48 AM   #3
pierrot
pierrot's Avatar
Is access to the wheel cylinder mounting bolt problematic due to the contol arm's attachment to the knuckle nearby? I've since converted my LS1's rear drum brakes to rear disc so I can't recall what that used to look like.
333,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Old 02-18-2019, 09:25 AM   #4
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
P B, a small hammer, and a drift pin for access to the bleeder. Wacking it really works for me. Did I mention patience? Then a new bleeder screw so the next person in there will have better luck.
Tom Walsh is offline   Reply With Quote
Clamp SC2 wheel cylinder Lightfoot2002 S-Series Tech 3 03-15-2014 04:39 PM
Replacing Wheel Cylinder bushkanaka86 S-Series Tech 7 01-25-2014 03:17 PM
leaking wheel cylinder BigBad2374 S-Series General 4 05-19-2009 03:16 PM
rear wheel cylinder goldenSL1 Miscellaneous Tech 3 08-19-2002 11:32 AM
Wheel cylinder leaking. HotShot Miscellaneous Tech 1 04-23-2001 05:28 PM
