Old 05-23-2018, 08:50 AM   #1
onlinebiker
Default Top or bottom?
Pulling engines, that is.
I asked a while back which was easier - removing an engine from the top, or like the factory - from the bottom by pulling the whole drive train.
There consensus was out the top.
I just finished pulling one out the top - for the first time - and I have to say - these guys know their stuff.
It was definitely easier removing it from the top.
But going back in?? It sure looks like a nightmare to me.
I guess if I am going to try that I need to get a good load leveler for my cherry picker.
That will have to be down the line - the car I' m putting this engine in needs a bit of work on the subframe so I will be dropping the whole subframe - then swapping engines and replacing from the bottom.
92 SC
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 05-23-2018, 09:07 AM   #2
Default Re: Top or bottom?
Put it back in the same way you took it out. Be aware it is very easy to break the master cylinder reservoir with the intake side cam cover corner when just starting back in. Your attention will be on getting the exhaust flange over the lower block flange and you will neglect watching the back side.
Old 05-23-2018, 10:00 AM   #3
Only pull the sub-frame if you're replacing it with a new-to-you one, otherwise it's not worth the hassle/risk of dealing with the subframe bolts. If you don't live in the rust belt you don't understand how much of a PITA those freaking things are and don't have to worry.
Load-levelers are cheap, this one is only about $25 shipped: https://www.amazon.com/Torin-Engine-.../dp/B004PX4YCI
If you got the engine/transmission out without the leveler (HOW?? lol) then you shouldn't need it for going back in, but it'll make the job far far easier. Just watch for sensors & stuff catching on the firewall lip and the exhaust manifold catching on the radiator support. You'll need to man-handle the engine around some to get the PS pump back where it belongs while you're dropping it back in and it's easier to get the downpipe between the engine and subframe brace before the engine is fully dropped in.
Old 05-23-2018, 10:35 AM   #4
Is there anything you can do ahead of time (e.g., tape bits of cardboard around the engine, or around brake master) that would help with the snagging, or to protect bits?
Old 05-23-2018, 10:58 AM   #5
onlinebiker
I have pulled many engines out the bottom - so yeah - I do know the subframe mounting bolts can be a pain. The thing I have learned is soaking the snot out of the bolts ( rear are easy - front a bit trickier) with PB Blaster for a few days ahead of time.
And take your time with a 1/2 inch breaker bar - no impact wrenches- and work the bolt back and forth with more penetrant.
If you hurry - it might take much, much longer.
92 SC
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 05-30-2018, 03:08 PM   #6
onlinebiker
It took two days - and the better part of a can of PB Blaster - but the bolts came out - of a 20 year old Michigan car - quite easily.
No substitute for patience.
92 SC
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 05-30-2018, 03:27 PM   #7
xenonracerx
xenonracerx is on a distinguished road
I was just reading a service manual that recommended removing the engine cradle and all the trimmings from the bottom. It made me wonder if it were possible to pull it through the top. Removing my engine isn't necessary and I hope that it never will be. This car has been in southern Nevada its whole life, but onlinebiker's post gave me flashbacks from when I was a in Ohio. Hot humid summers caused constant sweating, but having dirty, salty, ice water from the Ohio roads raining down on me from the melting fender-bergs was messed up. I quit my mechanics job and joined the Navy in 1988.
I broke two bolts that were holding the EGR down on my dad's 1991 GMC Sonoma back in 2013, but they were incredibly brittle. I put less than 10 foot pounds on these things. They were about 1/4"-28 Grade 5 bolts.
If you don't like the game, change the rules.
xenonracerx is offline   Reply With Quote
Old 06-02-2018, 01:19 AM   #8
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
If this is on the SW2 out the bottom and ditch that auto trans :P (I saw it on GR/Holland CL and glad it went to a good home , would of loved it but need to move some cars first)
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Saturninin is offline   Reply With Quote
Old 06-02-2018, 02:43 AM   #9
Medtactics
Medtactics is just really niceMedtactics is just really niceMedtactics is just really niceMedtactics is just really nice
Medtactics's Avatar
Tip for those, well any, rusty bolts, work back and forth, and keep applying acid base oil (IE; PB Blaster).
Or use an impact, following above advise if the fastener starts torquing.
If any user helped you, be sure to rep them.
Late 99 SC2 2.5 Gen, 237k miles
"Well... Now my car looks like a blackbarry." - Medtactics, 2017
Medtactics is offline   Reply With Quote
Old 06-05-2018, 09:57 PM   #10
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
The Vue we just did a clutch/slave cylinder on, had three of the four carriage bolts so rusted It was like They were welded. I just torched them out. there wasn't any way to get a wrench in there to hold them any way. Those little pockets seem way smaller than the S ones. I used a metric nut and a flare wrench to torque them. So I could retrieve my wrench after. I think it was a 22mm.
Tom Walsh is offline   Reply With Quote
Old 06-08-2018, 12:34 AM   #11
wheelhorse520
wheelhorse520 is on a distinguished road
Can you pull the engine out and leave the manual trans unbolted still the cradle or do you have to pull engine and trans as a unit?
wheelhorse520 is offline   Reply With Quote
Bottom out/struts Slingshot S-Series Tech 3 09-15-2009 01:18 PM
Out the top or bottom? thesameguy S-Series Tech 43 08-29-2009 06:53 PM
bottom end girdle sl2clone S-Series Tech 6 02-19-2007 10:42 PM
do i have a pop can tied to the bottom of my car iheartmysaturn S-Series General 10 12-28-2006 02:13 PM
