Old 04-24-2018, 11:10 PM   #1
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
2002 L-Series 2.2L Sedan
Default Lock cylinder availability
I just found out that the Vue and the S lock cylinders were the same thing! I looked at my dead Vue that is in line for some TLC, And The dash setup looked formidable. like it would be a bear to take apart. Guess what! the lock cyl in the Vue comes out like some one actually gave it some thought. A couple of wrenches and about ten minutes, if you are a smoker.
I used - 5.5 mm nut driver, 10 mm nut driver, 10 mm open end wrench, Battery powered nut driver, Odd picks. The top of the steering wheel shroud picks off. Three 5.5 mm screws drop the bottom part. Drop the steering wheel down and if you're not careful the 10mm bolts holding the cyl on will fall into your hand. A couple of wire molexes and you are done.
It's so nice to get to the source to harvest and have some time to experiment. There was one S in the yard and 5 Vues, so I figured I'd give it a shot. Now I can throw away my collection of lock cylinders that have no key.
Tom Walsh is offline   Reply With Quote
Old 04-24-2018, 11:29 PM   #2
Tom Walsh
Default Re: Lock cylinder availability
FYI - I posted an easier way to pull the S lock cyl a while ago. No pulling steering wheel, clock spring , etc, etc. If anyone can't find it I'll see if I can get it posted here.
Old 04-25-2018, 12:20 AM   #3
RobertGary1
Normally you just release the cylinder. Just push the button below with they key in accessory position and it slides out. A/c delco sells new cylinders with wafers to key it.
-Robert.
Old 04-25-2018, 07:32 PM   #4
Tom Walsh
Sorry I meant the Ignition assembly.
Old 04-25-2018, 08:29 PM   #5
Tom Walsh
And again I was wrong yesterday. The S and the Vue Ignition assembly are not identical. I checked that out today. The Vue assembly does connect to the S harness and clears passlock. My 2001 SL2 did start and run. The problem comes with mounting. The Vue Assembly has a larger bore and the bolt holes do not match with the S series attachment bracket. I did drill out some holes and it seems like it would work. I had to go back to work, so I'll have to revisit this as soon as time permits. Sooner than later hopefully.
lock cylinder ? Angry Plumber S-Series General 0 08-10-2016 11:42 AM
key-lock cylinder bigdude2468 2008 Vue 0 11-13-2013 05:14 PM
New lock cylinder kit # coolcat2 S-Series General 3 09-24-2013 11:13 PM
Key sticks in the lock position even after cleaning out lock cylinder. Uthinkso S-Series Tech 6 10-17-2012 08:27 PM
Door Lock Relay Availability sl2murk S-Series General 8 02-14-2005 03:55 PM
