Old 11-23-2015, 04:11 PM   #1
dhcp
dhcp has a spectacular aura aboutdhcp has a spectacular aura aboutdhcp has a spectacular aura about
2008 Astra XE
Default PO 420 Code
97 SW2 now with 311,000 miles. I got the PO420 code again today for the 2nd time, last time about 4k miles ago. I cleared it and as I explore the many potential causes I am not sure where to start. ETCS changed,,,,,200k ago as well as front O2 sensor. I may just toss some parts at it see how it goes. Thoughts are welcome and thanks in advance!!!
SOLD 11/2018 1997 SW2, Auto
Owned since June 2008
BOUGHT 9/2018 2008 Astra XE, 5 Spd
Acura TL 3.2, 1998
dhcp is offline   Reply With Quote
Old 11-23-2015, 04:32 PM   #2
Default Re: PO 420 Code
You can try searching past threads here dealing with this error code while getting some background info here and from googling P0420. Be aware to use only sources that deal with a straight interpretation of the code and associated issues to address. In general, high mileage suggests a worn out catcon and/or downstream O2 sensor.
Old 11-23-2015, 08:34 PM   #3
seac
seac has a spectacular aura aboutseac has a spectacular aura aboutseac has a spectacular aura about
seac's Avatar
I am getting that P0420 code once in a while. It usually comes on after I make an accelerating left turn. I think it might have to do with my exhaust pipes cracking open while making the turn. I use my OBD reader to delete the code every time. Since it doesn't affect my gas consumption, I am leaving it alone. I know my exhaust pipes need to be changed soon, so until then.
Saturn 2002 SL2
Still under 85K miles.
seac is offline   Reply With Quote
Old 11-24-2015, 12:39 PM   #4
SaberD
SaberD is on a distinguished road
2001 SC1
bad cat or bad post-cat o2 sensor
I'd start with the sensor if the cat isn't rattling
a pre-cat exhaust leak wouldn't introduce more oxygen to the system to set the p0420 code as exhaust gasses are only escaping and no additional oxygen is entering the system
SaberD is offline   Reply With Quote
Cleared out a code 19 and car runs great...Now I have a code 26 93 SL1 automatic. Pickleperforman S-Series Tech 5 05-01-2014 01:06 AM
SRS Airbag light on B1001 code & code reader ShawnV Vue Tech 11 11-13-2013 08:01 PM
F/S Actron cp9580 code connect scanner/ code reader ShawnV S-Series General 0 06-13-2013 05:25 PM
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 10:26 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
