Old 04-20-2012, 03:23 PM   #1
vladsaturn
vladsaturn is on a distinguished road
2001 SC1
Default traction control question
today by curiousity i undid the place where there is the dimmer for the gauge cluster lights. inside there where two connectors one for the lights the other probably for the traction control but this connection isnt connected to any switch ( i dont have traction control) if i was was to put in a switch would the traction control work ?
vladsaturn is offline   Reply With Quote
Old 04-20-2012, 04:24 PM   #2
Default Re: traction control question
Traction control is part of the ABS/TC system. No ABS, no traction control. Traction control is not a feature by itself. TC uses the same ABS circuitry and hydraulic system that ABS uses. They are a package.
Old 04-20-2012, 04:26 PM   #3
vladsaturn
2001 SC1
ahhh ok thank you
Old 04-20-2012, 06:06 PM   #4
With the way TC is implemented in these cave-man car's it's so useless when you need it that you get pissed off and turn it off so you can move and the rest of the time you....don't need it.
ABS works okay on pavement. Anything else and your screwed.
I had more problems with the 2 ABS & TC equipped S-Series I've had then the not equipped one's.
Old 04-20-2012, 07:43 PM   #5
vladsaturn
2001 SC1
hahahah ok thanks
ABS and Traction Control Question (02 SL2) nsr20de S-Series Tech 20 12-17-2007 01:07 AM
My VUE's lack of traction, "Traction Control" skijay Vue General 16 12-24-2005 12:17 AM
New Owner: FWD Traction Control Question scm64 Vue General 21 03-01-2005 08:06 PM
New to traction control Badger_Vue S-Series Tech 19 07-03-2002 09:09 PM
Traction Control Question for Sattech cityhawk S-Series Tech 8 02-08-2001 02:43 PM
