Old 01-04-2012, 03:02 PM   #1
coolgreany
coolgreany is on a distinguished road
coolgreany's Avatar
2002 VUE 3.0L
Default Heads Up: Ordering a Throttle Body Gasket for a DOHC or SOHC
I recently had an idling issue (fixed now) and ordered a TB gasket from Autozone. Based on prior reports that (for some reason) the parts shops had the SOHC and DOHC part numbers reversed I ordered both versions for a 2002 SL from Autozone.
Looks like the part numbers are still screwed up as the one that was supposed to be for a SOHC was the one that is used in my 2002 DOHC (orange rubber type). If you are ordering online I would order both!!
02 VUE Auto AWD-63k-Florida
02 SL2 Manual -76K, Germany
00 SL2 Auto-90K-failed emissions, Portland, OR
99 SL2 Auto-115K-aging, Portland, OR
91 SL1-Stolen 03, 113K
96 SL1-Totaled 02, 86K
coolgreany is offline   Reply With Quote
Old 01-04-2012, 03:30 PM   #2
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: Heads Up: Ordering a Throttle Body Gasket for a DOHC or SOHC
I had the same problem with Advance. THe guy sent in a request to fix it. Dont know if it actually did get changed.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
blue92 is offline   Reply With Quote
Old 01-04-2012, 04:17 PM   #3
I have a dumb question...How are you guys breaking the gasket to require a new one?
Maybe it's just 'cause I've got 2-3 hanging on the wall and a new one in a package next to the WP gasket... lol
Old 01-04-2012, 04:30 PM   #4
spacemanspif
spacemanspif will become famous soon enough
spacemanspif's Avatar
Could you list part numbers please? If both of these stores have everything mixed up then rock auto and others might be confused too. Part numbers would help clarify things.
Rock auto lists the same part number for single and dual cam, Felpro 61177.
-Mike
1995 SL2 5spd - Stock/MP2 trans swap - 258,XXX miles - 38mpg @ 65mph
1987 Monte Carlo SS - 5.3/4L80E swap - 13.92@103mph - 19mpg @65mph - needs POSI
spacemanspif is offline   Reply With Quote
Old 01-04-2012, 05:05 PM   #5
Or order based on a pic, if available.
It's the Inverse Preparedness Corollary to Murphy's Law. Gasket tears upon removal only if you don't have a spare on hand.
Old 01-04-2012, 05:07 PM   #6
Very true...
Old 01-04-2012, 05:10 PM   #7
IIRC RockAuto has the listings fixed and they also have pictures. Get the part number and take it to the FLAPS and tell them you want 1 of these. If they start the year, make, model routine tell them you want that part number.
Do SOHC Heads have the same problem with cracking as the 1994-1999 heads? BRIAN41920 S-Series Tech 2 10-22-2009 10:17 PM
Do newer SOHC heads have the same problem with cracking as the 1994-1999 SOHC heads? BRIAN41920 S-Series Tech 8 10-22-2009 02:53 PM
99 dohc heads on 96 sohc block youngrenton S-Series Tech 3 08-07-2007 08:10 PM
2001 SOHC throttle body on a 1999 DOHC Tatusmi S-Series Tech 1 07-14-2006 10:29 PM
96-97 DOHC/SOHC Hand bored throttle body Jeff_Snyder Classifieds 0 01-10-2005 04:21 AM
