Old 05-10-2009, 03:41 PM   #1
watso
watso is on a distinguished road
Mad 1998 manual transmission problems
Hi I have a 1998 Saturn SL1 manual transmision. The problem started the other day with high rev's I cleaned the TPS and it solved the problem for a bit. However today driving it I have no reverse, no 2nd gear and no 4th. I'm really hoping its not the transmission. Any suggestions on what to check. There are no leaks and the tranny fluids were just changed out. We just recently put in a new engine and the car has been driving just dandy
watso is offline   Reply With Quote
Old 05-10-2009, 04:03 PM   #2
rc1488
rc1488's Avatar
Default Re: 1998 manual transmission problems
Check the cables. Make sure they are secure and attached.
Check the fluid level.
Old 05-10-2009, 04:06 PM   #3
watso
sorry to sound like a tard...but what cables and where?
Old 05-10-2009, 04:54 PM   #4
SLCraig
The shifter cables.. Your gearshift is not directly connected to the trans. It uses cables. The cable connections underneath the hood can be found underneath the ducting for the air intake, behind the airbox and battery. The fluid dipstick is also right there, down low, with a red handle.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Old 05-10-2009, 05:11 PM   #5
It sounds like the housing clip for teh lower cable has come off. This is what it is supposed to look like. The big clip is a dealer only part.
Old 05-10-2009, 06:21 PM   #6
watso
It turns out one of the push rods that go into the housing clip is out. So that being said what do I have to do or buy to fix this problem?
Old 05-10-2009, 06:36 PM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
Iíve been replacing components.
Per the Factory Service Manual, they are named:
1. Shift/Selector Cable
2. Shifter Control Assembly (between the seats)
3. Shift Control Housing (on top of the transmission-)
4. Clutch Pedal (bushing worn and one was missing! Don't know how that happened!)
I replaced them one at a time and drove for a while. Each time, shifting noticeably improved.
You donít realize how sloppy everything is until you replace it.
Last edited by bumpdraft; 05-10-2009 at 06:39 PM. Reason: I honestly do not remember seeing an extra bushing lying around!
Old 05-10-2009, 07:15 PM   #8
watso,
Can you describe which part is not OK? The "U" shaped clip holds teh outer part of the shift cable in place on the transmission housing and the actual inner cable is held on the shift levers with the small clip. And you are describing the condition of the cables out at the transmission, right?
Bumpdraft,
Finally saw your viscosity lab experiment. Definitely shows that Mobil-1 has a problem with the cold pour point viscosity stability.
Old 05-10-2009, 07:35 PM   #9
watso
The rubber moulding that fits into the clip from the wire has come out. The rubber is still connected and it looks like it just needs to be reconnected. Hopefully
Old 05-10-2009, 08:38 PM   #10
Is there any chance you could get a photo of what you are describing? It would do wonders here.
If you do not have 15 posts the forum software will not let you post it here. If that is a problem just get a photo and there are alternate solutions.
Old 05-11-2009, 08:35 PM   #11
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by OldNuc View Post
Bumpdraft,
I haven't put it in yet. I will soon.
Replacing all the components REALLY improved shifting.
The Amsoil will hopefully be the end of trans issues for me.
Old 05-11-2009, 09:19 PM   #12
The new parts should help a bunch. If the tower ball is worn out then it really makes shifting sloppy.
Old 05-12-2009, 09:16 AM   #13
bumpdraft
bumpdraft's Avatar
1998 SW2
Yes. And they are not that expensive compared to the cable.
Shift now feels like the stick goes directly into the trans and not thru a cable.
It's like time-travel back to that New Car Feel
1998 Saturn SC2 Transmission problems daffyphil S-Series Tech 22 07-01-2011 05:22 AM
Will a 1997 saturn sc1 manual transmission work in my 1998 manual sl2? CARLiTO_ S-Series Tech 1 08-19-2008 08:52 PM
96 SC2 manual transmission problems dnvoss S-Series Tech 7 04-02-2008 07:53 AM
1998 Saturn SL2 Manual Transmission Cable broke for my wife S-Series Tech 5 02-02-2008 12:04 PM
Problems with Manual Transmission? bananaman Vue General 36 11-04-2003 10:49 AM
