Old 05-10-2009, 03:35 PM   #1
schreckman
schreckman is on a distinguished road
Default does broken timing chain damage valves?
Trying to find out if Saturns are interference design. My nieghbors 93 Saturn broke a timing chain and they want to know what it will take to fix it. Can I just replace the chain and tensioner or do i need to do a valve job as well?
schreckman is offline   Reply With Quote
Old 05-10-2009, 03:49 PM   #2
Default Re: does broken timing chain damage valves?
It is an interference engine.
Old 05-10-2009, 04:06 PM   #3
rc1488
rc1488's Avatar
Buy a new engine and drop it in. Its easier.
Old 05-10-2009, 04:11 PM   #4
chingondearmona
chingondearmona is on a distinguished road
chingondearmona's Avatar
Im not no expert nor giving advice but from what i know about the the belts/chains breaking, there could be a little chance the valves were damaged depends on how many valves the engine has, their for removing the head to inspect, the more cylinders the more possible the damage since a 4 cylinder block has a time frame when all pistons are level but the chanced would be down to a 5%
1995 Saturn SL2 DOHC 1.9 L
chingondearmona is offline   Reply With Quote
Old 05-10-2009, 05:06 PM   #5
1995sl1sohc
1995sl1sohc is on a distinguished road
1993 SL1
You'll need a valve job.
1995sl1sohc is offline   Reply With Quote
Old 05-10-2009, 05:28 PM   #6
bear8ruf
bear8ruf has a spectacular aura aboutbear8ruf has a spectacular aura about
You don't NECESSARILY "NEED" a valve job. An interference engine means that IF any valve is open all the way while the piston is at TDC, you will bend valves. I have gotten lucky before on a few engines. If the cam(s) stop turning quickly without a valve all the way open, the pistons may never contact any valves. This is most likely if it died at an idle.
bear8ruf is offline   Reply With Quote
Old 05-12-2009, 03:22 AM   #7
The unasked question here is -- how did he break the timing chain? It's nearly impossible on these cars; they make an awful lot of noise before breaking. And no, it's not just a "history" question - if the answer reflects on how the car was driven (and in all likelihood, it does), it may bear on whether you want to put time into helping your neighbor.
Old 05-12-2009, 10:11 AM   #8
Low Saturn
Low Saturn's Avatar
2007 AURA XR
I've bought two Saturns with broken timing chains. One was a parts car, the other was to throw a rebuilt engine into. Both people knew of the noise and ignored it. One actually took the car on a 600 mile trip with it that way.
They didnt make it home and I got a car for next to nothing. My grandfather ended up driving that car for a few years and now my brother drives it.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 05-12-2009, 10:30 AM   #9
OnDaGround
OnDaGround's Avatar
1993 SC2
Lack of oil will surely do it.
Saturnless...
2001 LW200 Timing Chain Failure - Head Damage fish_skier L-Series Tech 10 11-30-2008 10:46 PM
Tapping Valves or Timing Chain or ?!?!?!?!? cfg83 S-Series Tech 16 03-04-2007 01:49 PM
stalling problem after replacing timing chain, valves ls1racer ws6 S-Series General 4 02-19-2006 05:50 PM
stalling problem after replacing timing chain, valves ls1racer ws6 S-Series Tech 0 02-19-2006 04:23 AM
Timing chain/ valves mozart3851 S-Series Tech 10 08-18-2005 11:21 PM
