Old 12-30-2007, 02:05 PM   #1
Spazie
Spazie will become famous soon enough
Spazie's Avatar
1993 SC2
Default Bringing 94 SL1 back to life - been sitting for 3 1/2 years
Alright, my old 94 SL1 has been living in my grandma's garage since May of 2003. I'm trying to bring it back to life, and I'm wondering what all I should look at replacing due to it being in un-prepped storage for so long, beyond fixing what was wrong with the engine that caused it to stop running.
Right now I'm planning on replacing:
tires
air filter
spark plugs and wires (these haven't been changed since I got the car originally so I'm sure it wouldn't hurt)
Anything else I should do? Gaskets, brakes, fuel filter?
It's a basic SL1, has a sunroof (which needs to be fixed, I cannibalized it when my SC2's roof seized up), auto transmission (worked great before car died), and A/C as the only options. Everything else is completely basic including the stock am/fm radio! Has about 115,000 miles on it.
This car will be going to someone that can't afford to do a lot of maintenance on it, so I'm hoping to get it into a condition where she won't have to spend any money on it for at least the next 2 years except for oil changes and tire rotations.
13 Chevy Equinox, 46k, built in Spring Hill!
04 VUE 3.5, 196k
99 SL2 Homecoming, 211k
Spazie is offline   Reply With Quote
Old 12-30-2007, 04:22 PM   #2
02Saturnlady
02Saturnlady will become famous soon enough
2001 SC1
Default Re: Bringing 94 SL1 back to life - been sitting for 3 1/2 years
Hi Spazie - you might want to think about replacing the hoses as well and the serpentine belt. The temp fluctuations of sitting in a garage can wreak havoc on anything rubber. Just to be on the safe side you might want to replace the thermostat as well. Sounds like you're doing a nice thing for someone so I hope it doesn't get to expensive for you. Happy New Year
02Saturnlady is offline   Reply With Quote
Old 12-30-2007, 06:01 PM   #3
yogi1200
yogi1200 is on a distinguished road
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
I would replace the ECTS, check the how to library, It can cause alot of little and large problems if it's bad. Also check your SES (service engine soon) codes. You can find all kinds of info that way. (If the SES shows up on the dash panel) Good luck!
yogi1200 is offline   Reply With Quote
Old 12-30-2007, 06:28 PM   #4
rc1488
rc1488's Avatar
Learning fast
Your pretty much doing a Tune up:
replace ECTS
replace connector for ECTS as needed
new spark plugs and wire (NGK Copper all the way)
check brakes-replace as needed (adjusting rear drums if equiped)
check belt - replace as needed
check coolant level
change oil and filter
change transmission fluid (if automatic) and filter
clean throttle body and all passages
clean air filter
check power steering fluid
check brake fluid
check tire pressure
and a nice cleaning of anything you can reach on the engine can always make your car a little happier
Have you fixed the issues with why it died in the first place?
Old 12-30-2007, 07:07 PM   #5
yogi1200
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
Since I'm new to this, Is a good power wash with engine degreaser ok on all the electric components? I use to work on good old fashioned sb chevys etc.. I'm not used to all this electronic stuff. What we use to blast with water now has electric connections! Is it okay to hi-pressure blast the engine bay?
Old 12-30-2007, 07:40 PM   #6
rc1488
rc1488's Avatar
honestly....i would never spray water inside the engine bay in any car now adays. supposedly the connectors will be alright, however if I were you i wouldnt risk it
Old 12-30-2007, 08:25 PM   #7
TwinRevver
TwinRevver is on a distinguished road
The brakes and rotors/drums are gonna be rusty to hell and wouldnt work for shti Replace due to the fact ur giving to some1 w/ low mantinece (sp)
dont change the tranny fluid yet until u drive it around and see how it (mis)behave :chuckle: it'll be abit sloopy soup ish
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
TwinRevver is offline   Reply With Quote
Old 12-31-2007, 12:51 AM   #8
Spazie
Spazie's Avatar
1993 SC2
Thanks for all the replies folks!
02SaturnLady - this car's going to be worth far more to my friend than it is to me just sitting around collecting dust, I can't wait to see the look on her face when I show up with the keys! It'll be completely worth every penny I've spent on it! (She has NO idea that I'm planning this, and was planning on buying a car with her tax return - I'm getting it fixed and giving it to her before then.)
yogi - the infamous ECTS! I think I've already replaced the one in this car, but I'm definitely going to check it out before all is said and done.
rc - excellent list! Where can I find NGK plugs at?
I still don't know exactly what's wrong with it (there's two or three theories floating around) - basically, it will start and turnover (with a jump, now) and run for about 10-20 seconds before the engine will just sputter and die. There's plenty of oil on the dipstick, but just seconds before it died on me while driving, the oil light came on, so it may be a sending or pressure problem.
A good friend (and SF member) who has already bought one broken down car from me and fixed it back up, is going to be fixing this one up for me. He'll find the problem in no time, I'm sure! I'm trying to make a list of parts for him so he can check prices through his connections compared to what I can find them for, so we can get them ordered. I'll be towing this car to him in a week or two (we're waiting on a settlement check - and using part of it to pay for fixing up this car) and hopefully will be able to give it to my friend before the end of next month.
Twin - I'll try and check the brakes, you're probably right about them being rusty. I want to check the condition of the rotors but I'll most likely be tossing new pads and rotors on the front anyway so she won't have to worry about getting them done. Hopefully the tranny will behave - it was in very nice condition when the engine pooped out!
04 VUE 3.5, 196k
Old 12-31-2007, 02:03 AM   #9
rc1488
rc1488's Avatar
You can find them at autozone or advanced auto for sure.
Also to add to the list is to change fuel filter if needed That may be your starting issue also. Good luck!
Old 12-31-2007, 03:03 AM   #10
yogi1200
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
It sounds like it may be a fuel or electric problem. If it starts and runs for a few secs. then dies. could it be a clogged fuel filter? enough gets through to start but not enough to run? or the ignition is not fireing when needed?
Old 01-01-2008, 12:05 AM   #11
Can't say that this is the problem for sure but 3 1/2 year old fuel or what is left of it is not doing you any favors. If you have not yet put in some/alot of new fuel I would try it.
Old 01-01-2008, 12:35 AM   #12
yogi1200
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
Fuel stabilizer couldn't hurt either.
Old 01-01-2008, 12:29 PM   #13
Spazie
Spazie's Avatar
1993 SC2
That's not the problem that caused it to die originally, for sure.
But we'll probably need to drain the fuel tank because the gas has been sitting in it since 2003.
04 VUE 3.5, 196k
Old 01-01-2008, 12:39 PM   #14
kaviation
kaviation has a spectacular aura aboutkaviation has a spectacular aura aboutkaviation has a spectacular aura about
kaviation's Avatar
2003 ION-2 Quad Coupe
Don't forget to double check the wiring in the engine, sitting that long, you never who may have nested inside that car. Maybe even some bees in the HVAC vents. Good luck, and you are doing a great thing.
2003 Ion QC- Sold August of 2015
2016 Toyota RAV4 LE AWD
2004 Ion Redline
Meth Injection, WOT Box, Stage 2, Fidanza aluminum Flywheel, Spec clutch Stage 2+
I ENJOY WHAT I DO- I DO WHAT I ENJOY
kaviation is offline   Reply With Quote
Old 01-01-2008, 02:42 PM   #15
Motorhead62
Motorhead62 is on a distinguished road
Motorhead62's Avatar
2008 AURA XE
2001 L-Series 2.2L Sedan
Wrench Re: Bringing 94 SL1 back to life - been sitting for 3 1/2 years
FYI = Adding fuel stabilizer to old fuel will do nothing. Fuel stabilizer is to be added prior to parking a vehicle. You can add octane booster and fill the rest of the tank with super unleaded. Draining all the old fuel out of the tank is also an option.
Change the fuel filter after running a fresh tank of fuel throught the engine.
For sure change ALL the fluids in the car and inspect everything else. Replace parts as needed from the inspection.
Good Luck!
Chris
AKA "Motorhead62"
2008 Aura XE EcoTech 2.4
2001 L200 EcoTech 2.2
1993 SL1 1.9L
1967 Chevelle "496" BBC
1967 El Camino "388" SBC
1967 C-10 "463" BBC
www.C-DPerformance.com
Motorhead62 is offline   Reply With Quote
Old 01-01-2008, 06:18 PM   #16
mjo
mjo is on a distinguished road
mjo's Avatar
I learned from a thread on bobistheoilguy.com that motor oil does have a shelf life. The colder the oil the shorter the life.
With the car sitting for 3 1/2 years most of the additives should have settled out of suspension. I second the "change all the fluids in the car".
I would do a flush on all the fluids. With the oils the gentlest way IMO is to use Auto-RX to remove the sludge and other deposits that inevitably accumulate after such a long time.
You can also run a high detergent oil (such as a decent diesel oil) and run short oil change interval once (say 100 miles) and then progressively longer OCIs until 3000 miles.
Check how spongy the radiator hoses are. Also, old hoses can become brittle and split during operation - especially if the hose is dry (i.e. upper rad hose).
If the battery has drained lower than 12 V (most likely) you may want to just replace it. When discharging a lead-acid battery (especially the non-deep-discharge variety) deeply, deposits will form on the plates.
mjo is offline   Reply With Quote
Old 01-01-2008, 06:45 PM   #17
mjo
mjo's Avatar
Be prepared to change all your filters soon. They are going to clog up.
Old 01-01-2008, 08:22 PM   #18
Spazie
Spazie's Avatar
1993 SC2
Ok, so far my list has expanded to:
draining fuel tank, adding new fuel
coolant change
transmission fluid change
replace battery (easier to just replace than to worry about whether it will hold a charge)
change all filters (fuel, air, any others I'm missing?)
check and change ECTS if necessary
check and change radiator hoses as necessary
oil change was a given, the engine's going to be half torn-down anyway
04 VUE 3.5, 196k
Old 01-01-2008, 09:13 PM   #19
rc1488
rc1488's Avatar
coolant change
if it hasnt been changed at all, then its probaly a given to change the ECTS. even a small crack (sometimes invisible to the naked eye) is enough to cause problems
Old 01-02-2008, 02:19 PM   #20
eljefino
eljefino's Avatar
1995 SW1
Get it running right before you spend money on tires, hoses, even the serp belt.
With new front rotors the car will stop safely enough to get the car tuned up driving around the block. Drums are more resistant to rust related problems and will scrape themselves clean after a while... and contribute little to braking anyway.
Once you have it running right, then go to "phase two" with all new tires, belts, hoses, etc. A new battery may also be worthwhile. Don't change the oil until you have it at least running-- check it, sure, but don't change it. Who cares if the additives fell out of suspension, the oil still works as oil for that critical first start. If you change the oil then you have a few seconds of dry running.
Actually, may be prudent to pull the fuel pump relay and crank it over-- 20 seconds on, 20 off, repeat-- until the oil light goes out.
Before you start it the first time, pull the air filter and the intake hose off and make sure squirrels haven't set up shop, leaving acorns everywhere etc.
You may want to get a cheap fuel pressure tester from harbor freight, they're only $10 and it may be good to watch that when the car stalls out.
92 Sl2 saturn sohc been sitting for 3 years altean S-Series Mods 4 11-24-2009 09:09 PM
Could Magnas Unique Business Model Lure Penske into Bringing the Astra Back to Lif wifeofcore General Saturn Discussion 14 06-18-2009 12:46 AM
bringing a $400 SC2 back to life geartooth94 S-Series Tech 9 01-12-2005 09:31 AM
Pulling some fuses brought my dead SL1 back to life...AGAIN! WHY? GmG S-Series Tech 9 11-23-2003 12:38 PM
OT: I have a car that's been sitting for 5 years 1991SL Miscellaneous Tech 9 07-21-2003 11:20 AM
