Old 08-06-2007, 06:37 PM   #1
youngrenton
youngrenton is on a distinguished road
Default 99 dohc heads on 96 sohc block
I know this question, or thousands very similar have already been asked. But... It never hurts to ask a question... Other than gskets, what do I need to make 99 dohc heads fit on a 96 sohc block? Any piston/valve swapping? Please let me know... Thanks
youngrenton is offline   Reply With Quote
Old 08-07-2007, 11:47 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: 99 dohc heads on 96 sohc block
The reason you aren't getting any answers is because it's a '99. '99 was a transition year where a lot of things changed in the middle of the model year. The head will fit the block. However, if it's the later year '99, you'll need a lot of other stuff along with it like the manifolds and downpipe. If you have a donor car, you can probably pull it off.
Old 08-07-2007, 05:18 PM   #3
youngrenton
I have got a 99sc2 and the motor is knocking pretty bad. So I wanted to put the bottom end of the 96 sohc under all the rest of the 99 dohc stuff... I will check on the build date our the sc2 if that helps any...
Old 08-07-2007, 08:10 PM   #4
BarnOwl
BarnOwl's Avatar
If you have the whole '99 engine, you have everything to make it work.
Do newer SOHC heads have the same problem with cracking as the 1994-1999 SOHC heads? BRIAN41920 S-Series Tech 8 10-22-2009 02:53 PM
01 DOHC on 97 SOHC BLOCK?? Saturntrip S-Series Tech 8 02-20-2008 02:25 AM
DOHC on a SOHC block? corey-c S-Series Tech 4 04-24-2006 06:53 AM
DOHC vs SOHC block, rods etc etc jasonsl2 S-Series General 1 02-17-2005 09:22 PM
Is every engine block identical? SOHC/DOHC alkemyst Miscellaneous Tech 6 02-04-2003 09:27 AM
