Old 02-13-2020, 09:39 PM   #6441
toggenburg
toggenburg's Avatar
That's a really nice green color.
Old 02-13-2020, 11:28 PM   #6442
Waiex191
Waiex191's Avatar
^+1, the wrap looks great!
I checked my tire pressures and found them ranging from 25 to 10 psi. I hate aluminum wheels and cold temps.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 02-14-2020, 06:47 PM   #6443
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by bumpdraft View Post
Bought two new Blizak tires in the wider 195 width so that I can run front tire pressure closer to the Saturn factory door sticker recommend pressure...
Yes, problem solved! The front suspension thanks me
Also, if you kids ever want to know the first sign of getting old, well...I just bought one of these:
LED Safety Flare, Amber, Operating Life Up To 150 hr. Steady, 80, 000 Millicandela
http://www.grainger.com/product/5NJU...PShare-_-5NJU3
Because, https://www.detroitnews.com/story/ne...sh/4721503002/
Note: The flasher wont save you, but it might help. Nothing to do with the news story, but Ive heard that drunk drivers will stare at a flasher and drive right into them. Be careful.
Old 02-18-2020, 10:04 PM   #6444
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
Pulled a drivers door from a 93 SW2 at the local Pick-N-Pull to have a backup manual window regulator. This part has gotten so rare, and a lot of them in the yards are broken, so I picked up a good part while I could.
A2Saturn is offline   Reply With Quote
Old 02-22-2020, 11:49 AM   #6445
Zeebins
Zeebins's Avatar
Did this on Tuesday, but the forms have been down.
Put on the shorter 778 serpentine belt. It finally solved the rattling the belt tensioner would do at idle in reverse/ drive, or under a lot of load. Also gave it its first wash in about 2 months. Its already kinda dirty again, but it looked nice for about a day lol
97 SL2, auto, 119K miles
Old 02-24-2020, 12:43 AM   #6446
98_Gold_Uranus
98_Gold_Uranus's Avatar
Thought about a motor swap...
But in the end, ended up selling the engine and used the funds to buy some ATV's and a trailer for the wife and I
Her name is Uranus :)
Old 02-26-2020, 03:20 PM   #6447
Zeebins
Zeebins's Avatar
Added a small volt gauge to the center console
Edit: Does anyone know a good accessory wire I can tap into? I currently have a relay set to come on with the ignition, but only in the run position. Id like the relay to come on with the key in the accessory position.
File Type: jpg B740B9BD-12A4-481E-97E9-73E431968EC7.jpg (148.0 KB, 9 views)
File Type: jpg 4A20A4BE-CC0B-4BFC-A536-BBDD30546072.jpg (131.3 KB, 9 views)
Old 02-26-2020, 04:16 PM   #6448
trottida
trottida's Avatar
Edit: Does anyone know a good accessory wire I can tap into? I currently have a relay set to come on with the ignition, but only in the run position. I’d like the relay to come on with the key in the accessory position.
Too late but you may have considered this instead.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
trottida is online now   Reply With Quote
Old 02-26-2020, 04:31 PM   #6449
Zeebins
Zeebins's Avatar
I did consider a few different styles with usb ports, but I wanted to keep the original cigarette lighter anyway so I figured I wouldn't need them. (I may change my mind later on this, I'm very indecisive )
Old 02-27-2020, 06:24 PM   #6450
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
Originally Posted by 98_gold_uranus View Post
thought about a motor swap...
But in the end, ended up selling the engine and used the funds to buy some atv's and a trailer for the wife and i :d
lmao ls ftw :d
http://www.youtube.com/velocitylabs
ErikTande is offline   Reply With Quote
Old 03-01-2020, 10:22 PM   #6451
Zeebins
Zeebins's Avatar
Grabbed a map light from the junkyard to add to my non-sunroof equipped Saturn. Just had to cut a hole on the headliner board and run 2 wires up to it. Its a pretty tight fit since the sunroof headliner board has more room behind it for everything. I had to chop off the two pegs that normally hold it onto the roof to make it fit. I left the sunroof switch in so I dont have to look at an empty hole, but I may repurpose the space with something else later.
File Type: jpg D5B3A0A4-A789-4C02-93C5-D74D514A9534.jpg (144.1 KB, 16 views)
File Type: jpg 79E2DCB3-D2AA-4707-B734-4B5CA82E315C.jpg (97.5 KB, 15 views)
File Type: jpg E454F8A4-19A7-43DD-83E0-C28D2259EB48.jpg (102.1 KB, 16 views)
Old 03-07-2020, 04:14 PM   #6452
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Bought Pennzoil High Mileage 5w30 and a Motorcraft FL400s filter today. Last weekend we sold my sisters Chevy Malibu (my old car back in high school) and got cash and an 03 Saturn Ion for trade. Guy said it needed a head gasket, but literally just needed a new hose and some coolant. Mechanics really trying to get people these days smh. Turned around and sold the Ion to my uncle so two cars sold in a weekend.....to pay for my Saturn's oil drinking habit!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 03-07-2020, 07:25 PM   #6453
Waiex191
Waiex191's Avatar
We have two Saturns at home currently.
I used Wolfman's awesome guide to program two additional remotes, and used 11 cycles to get rid of the stupid alarm thing. It's a $500 car and a manual.
http://www.saturnfans.com/forums/showthread.php?t=59192
Here is my jumper for program mode. This is the '98 SC2.
Bryan Cotton
Old 03-12-2020, 06:54 PM   #6454
bumpdraft
bumpdraft's Avatar
1998 SW2
Removed the winter steel wheels and installed the summer wheels
The new steel winter wheel was one I ebay bought to replace a new bent ebay bought steel wheel.
New Bent:
New Replacement:
The replacement was hub-centric & snug to the point I could not remove it until I used a puller. A puller that barely fit. But at least it fit.
Old 03-13-2020, 01:23 PM   #6455
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Originally Posted by focusofheart View Post
OK Guys - this will give you a giggle.
A short time ago I replaced my headlights and was pretty happy with how they came out. Unfortunately, I had failed to see a plastic 'hook' that helped hold the headlight into place properly and had to redo them last night. I was wondering why they were in a little different position than the old ones. Details, details.
You aren't the only one who missed that detail.
I bought a set of headlights last year to replace one that had the vertical adjustment broken, and eagerly installed them along with 9011 and 9012 bulbs. Imagine my surprise when I had to have the headlights almost cross-eyed just to have the beams pointed in a somewhat forward direction, despite fully functioning adjustment.
Until I saw this post, at one point the SL had one light pointed forward and one scanning trees for squirrels and birds. Once I finally hooked the lights into place, I was actually able to adjust the lights properly and make them point forwards... wild, right?
Also, I was able to replace the foam seal for the fresh air intake on the cowl (thanks to alordofchaos). It turned out alright, I guess --I was trying to channel my inner Dummo for sculpting this properly.
Goggles Pisano is offline   Reply With Quote
Old 03-13-2020, 02:35 PM   #6456
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
my newest tool box thanks to Kaervak
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Old 03-14-2020, 12:08 AM   #6457
Zeebins
Zeebins's Avatar
Did an oil change today without jacking up the car. I read that you can get access to the filter by just turning the wheel all the way to the left and doing that worked great. With the car still on the ground, the sway bar became a nice place to prop up the filter to drain
The drain plug was also only on finger tight when I removed it and I have no idea how it hasn't been leaking like crazy the past 6 months. Snugged it up good this time.
Old 03-19-2020, 12:07 AM   #6458
Goggles Pisano
1999 SL1
Cleaned the EGR and performed an MMO soak a couple of days ago, and put the plugs back in today. There was leftover MMO in cylinder #1, but not in the others.
When I put the plugs back in and started the car, I put on a smoke show that rivalled the Kiss Destroyer tour of 1976. It lasted a good couple of blocks before it finally went away.
Old 03-19-2020, 09:52 AM   #6459
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SL2
Mine also loosens up from time to time. Very concerning..
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Old 03-20-2020, 09:16 PM   #6460
Waiex191
Waiex191's Avatar
I pulled the 98 SC2 into the hangar. Illinois is going under a shelter in place order starting tomorrow due to the coronavirus. I plan to fiberglass my broken door skin mount tabs, replace my window motor and regulator, and replace the aftermarket ignition key with a properly keyed OEM one. I'll be working from home for 3 weeks and won't need to drive.
Bryan Cotton
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
