Old 05-29-2011, 12:04 AM   #1
tallNewfie
tallNewfie is on a distinguished road
2009 Astra XE
2009 Astra XR
Sad P2096 code
Well, isn't it funny how you always seem to have car trouble at the most inopportune times. I had left California to make my way back to Texas after vacation, and when I got in Vegas (passing through) the check engine light came on. So I swung by an autozone to get it read. They came out with a p2096 code and suggested it could be a sensor malfunction, however he highly suggested that I get it looked at before continuing on. But since it was 5:00 on a saturday of a holliday weekend, no service places were open and probably wouldn't be until tuesday. I probably could have found a small service shop to take a look, however they probably would have had no clue and would have had to wait until Chevy opened to get parts. So I thought, I will just go on and see how it goes, however upon getting on the highway the car is really having issues with acceleration and power. I don't want to force it for fear of burning up a piston.
Any thoughts on what it could be or if it would be dangerous to keep driving. I made it to Arizona tonight (kingman), however I have quite the drive ahead of me. I am going to break it up into two days and probably take it quite slow, but just wanted to see what the more knowledgable members think. Hopefully someone will glance at this post before I leave tomorrow morning, but if not I will be checking in at McD's along the way (free wifi).
Thanks for any advice you may have!!
~~ Bryan ~~
2009 Astra XE - manual, wired FM mod
2009 Astra XR - auto
2001 SC2 - manual, sunroof (retired)
tallNewfie is offline   Reply With Quote
Old 05-29-2011, 03:23 AM   #2
Default Re: P2096 code
Never leave Autozone telling you what they see on their readers. Either ask them for the entire readout or insist on reading the error code yourself so you have all the info.
P2086 Post Catalyst Fuel Trim System Low Limit
There are many posts on other forums outside Saturnfans that seem to point to mods done like "foulers", poor/loose connections, exhaust system leak, worn out rear O2 sensor, damaged catalytic converter. Resetting the error is the first try and the error code coming back means more troubleshooting.
A blocked catcon may be possible. Not posting mileage or any other pertinent info prolongs feedback.
VCX NANO
Old 05-29-2011, 08:49 AM   #3
tallNewfie
2009 Astra XE
2009 Astra XR
Hey fdryer,
I did actually get the readout from them, however didn't get the code reset. Probably should of said that.
I appologize for not including the extra info, I don't know how that slipped by me. It's an 09 XE 4dr, manual trans, with approx 50,000km (maybe 30,000miles). I'm the original owner, and no other repairs or mods have been done to it except for fm transmitter.
Thanks!
~~ Bryan ~~
Old 05-29-2011, 09:05 AM   #4
bdshaffer
bdshaffer is on a distinguished road
bdshaffer's Avatar
2008 Astra XE
DTC Descriptors
DTC P2096
Circuit/System Description
The engine control module (ECM) controls the air/fuel metering system in order to provide the best possible combination of driveability, fuel economy, and emission control. Fuel delivery is controlled differently during Open Loop and Closed Loop (CL). During Open Loop, the ECM determines fuel delivery based on sensor signals without heated oxygen sensor (HO2S) input. During CL, the ECM adds HO2S inputs and level of purge to calculate the short and long term fuel trim (FT) adjustments. If the HO2S indicates a lean condition, the FT values will be above 0 percent. If the HO2S indicates a rich condition, the FT values will be below 0 percent. The short term FT values change rapidly in response to the HO2S voltage signals. The long term FT makes coarse adjustments in order to maintain an air/fuel ratio of 14.7:1.
Conditions for Running the DTC
P2096
DTCs P000A, P000B, P0010, P0011, P0013, P0014, P0016, P0017, P0030, P0031, P0032, P0036, P0037, P0038, P0068, P0101, P0102, P0103, P0116, P0117, P0118, P0119, P0121, P0122, P0123, P0130, P0131, P0132, P0133, P0137, P0138, P0139, P0140, P0141, P0171, P0172, P0201, P0202, P0203, P0204, P0221, P0222, P0223, P0261, P0262, P0264, P0265, P0267, P0268, P0270, P0271, P0300, P0301, P0302, P0303, P0304, P0313, P0335, P0336, P0340, P0341, P0365, P0366, P0420, P0443, P0458, P0459, P1101, P2088, P2089, P2090, P2091, P2100, P2101, P2176, P2270, P2271, P2297, P2300, P2301, P2303, P2304, P2306, P2307, P2309, P2310, P2A00, P2A01 are not set.
The ignition is ON.
The EVAP system is not purging.
The post catalyst fuel trim is enabled.
These DTCs run continuously when the above conditions have been met.
Conditions for Setting the DTC
P2096
The long term FT has reached its limit while the HO2S voltage is still trying to move the adjustment further in the same direction.
Action Taken When the DTC Sets
DTCs P0171 and P2096 are Type B DTCs.
Conditions for Clearing the MIL/DTC
bdshaffer is offline   Reply With Quote
Old 05-29-2011, 09:16 PM   #5
Lunchbox1984
Lunchbox1984 is on a distinguished road
Lunchbox1984's Avatar
2008 Astra XR
2003 L-Series 2.2L Sedan
Dam, that sucks bro, i hope you get it repaired or cleared so you can make it back home safe.
i think we should all show up at the Munday Chevy Dealership and give them our cars(im having issues with mine, lose of power during acceleration and valves tapping like a SOB) and see if they will actually fix our problems. They dint fix mine the first time i took it too them, but its still doing it.
Mines throwing out Cam Sensor Code and it pissing me off that it hasnt been fixed.
Bertha [2008 F250 S.D.] 4dr|6.4ltr Diesel 350HP|4x2|6ft bed.
RED [2008 Sat. Astra XR] 2dr|1.8ltr Ecotec 140hp (will be missed)
Oggly [1984 Isuzu Trooper II] 2dr|2.0Ltr G200 89HP|White|4sp manual
Lunchbox1984 is offline   Reply With Quote
Old 05-31-2011, 10:41 PM   #6
tallNewfie
2009 Astra XE
2009 Astra XR
Hey guys, thanks for all the input on this. I am made it all the way back to Texas without any further problems. The day after I had the issues, I had no more major troubles with the car. At times, it did seems like it had slightly less power than normal, but it could have been my mind seeing what it wanted to. The light is still on though, so I will have to bring it in to get it turned off/checked out. I haven't had any major servicing at my local dealer yet, so I will see how it goes. Usually services in general are better outside of newfoundland (my home province), but in this instance it would be better if I was there since all the techs that worked at Saturn have moved to the chevy dealer.
Is this your local saturn service agent where you are in Houston? It sucks that you are still having trouble. Hopefully my local place will do better, but we'll see. :-)
~~ Bryan ~~
Old 05-31-2011, 11:00 PM   #7
Lunchbox1984
2008 Astra XR
yes, that is the Northside Dealership that covers Saturns. im going to check, there is suppose to be one in Pasadena on 225 and beltway, but i have to call them and see if they do saturns as well.
Keep me up to date Newf, maybe we both can bombard Munday Chevy and give them a run for the money, lol.
Old 05-31-2011, 11:22 PM   #8
tallNewfie
2009 Astra XE
2009 Astra XR
Will do! Although I'm not sure that they will give me a courtesy ride to work at A&M.
~~ Bryan ~~
Old 05-31-2011, 11:45 PM   #9
phatfire6
phatfire6 will become famous soon enough
phatfire6's Avatar
2008 Astra XR
Its errors like these that make me want to buy those bluetooth ODB scan tools that I can connect to with my phone. It would be easy to identify if you are getting odd voltages from the downstream O2 sensor, and replace it based on the info it provided.
phatfire6 is offline   Reply With Quote
Old 06-01-2011, 11:45 PM   #10
Lunchbox1984
2008 Astra XR
i have gone to the step of barrow my dads ODB Cable box, and hook it too my Netbook. i run EasyODB software(i paid the 20 bucks for the commerical) and found i had a Cam Sensor flakin out. ive been driving to work and home the past couple of days and havent had one issue(been using the a/c as well, figure only would do it when a load was on) and i havent had one problem. i still think i have a cam sensor or sensors going out, but im waiting for that dam engine code to pop back up and when it does, its getting taken back to Munday Chevy. Bring backs are not good for service, so im gona be straight forward this go around.
If nothing gets taken care of, looks like the BBB, Newpapers, and News will be getting involved if i have too.
Old 09-02-2016, 01:27 AM   #11
tallNewfie
2009 Astra XE
2009 Astra XR
Hey Everyone,
I just realized that I never got back to this thread with the fix. It was a rear O2 that was replaced back in 2011. I have been having acceleration problems again recently and just yesterday got the P2096 again. So it looks like 5 years later, the O2 is gone again.
Cheers!
Bryan
~~ Bryan ~~
Old 09-02-2016, 06:38 AM   #12
Saturn4Ever
Saturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the rough
Saturn4Ever's Avatar
2009 Astra XR
Originally Posted by tallNewfie View Post
Hey Everyone,
Cheers!
Bryan
Curious, what was the mileage each time his happened?
2009 Saturn Astra XR, 140,000 km
2018 Chevy Traverse Redline 52,000 km
Past vehicles:
2000 Oldsmobile Alero, 220,000km - Sold
2008 Saturn Outlook XR 280,000 km - Sold
Saturn4Ever is offline   Reply With Quote
p2096
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 10:26 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
Code Scanners vs. Code Readers, What to get? jeffghs S-Series Tech 2 10-12-2005 12:40 PM
Trans code 25, engine code 32, 1993 sl-1 1993 S-Series Tech 3 06-27-2004 11:13 PM
vin egine code to original code how to check? silver97sl General Saturn Discussion 1 01-12-2004 05:17 PM
