Old 09-06-2011, 09:47 PM   #1
cwl5005
cwl5005 will become famous soon enough
cwl5005's Avatar
2004 VUE Red Line
Default energy suspension bushings
I have a 01 sc2 and I was thinking of having energy suspension bushing kit installed. Has anyone done this and is it worth doing? if anyone can help that would be great.
cwl5005 is offline   Reply With Quote
Old 09-06-2011, 09:55 PM   #2
Evil_SL2
Evil_SL2 is on a distinguished road
Default Re: energy suspension bushings
would these happen to be the same thing? http://www.sixthsphere.com/forum/sho...actory-Housing!
Evil_SL2 is offline   Reply With Quote
Old 09-06-2011, 10:56 PM   #3
Redhotftw!
Redhotftw! will become famous soon enough
no.
Why do you want ES?
Certain ones are good, others there is no reason to replace unless they are bad and some just suck.
Example: the LCA to subframe bushings. The ES ones are historically terrible. On that location the best replacement is the Moog rubber.
1998 "Red Hot" Sc2
Redhotftw! is offline   Reply With Quote
Old 09-07-2011, 02:18 AM   #4
Evil_SL2
Originally Posted by Redhotftw! View Post
no.
Why do you want ES?
Thanks for clarifying that for me Redhot.
Old 09-07-2011, 09:32 AM   #5
Tom92SCm
Tom92SCm has a spectacular aura aboutTom92SCm has a spectacular aura about
Tom92SCm's Avatar
I replaced all my rubber bushings with the ES bushings on my '92. It was my autox/track car.
Was it worth it? It took me and a friend an entire weekend- lots of fasteners didn't want to come out. I had to replace both rear lateral link to knuckle (upright) bolts. I had burnt rubber stains all over my garage floor and driveway. They were loud and creaky during the winter. And the right sway bar to LCA bushing came apart at an autox. For a street only car- definitely not worth it. For a play car like mine- I would not have done it when I did it (it was one of the first mods to the car).
Not a Saturn.
Tom92SCm is offline   Reply With Quote
Old 09-07-2011, 07:05 PM   #6
cwl5005
cwl5005's Avatar
2004 VUE Red Line
i was looking at
HyperFlex Master Kit Saturn S Series 91-02
Part Number: 18.18101
thank you for all the replies
Old 09-07-2011, 09:38 PM   #7
droveavolvoonce
droveavolvoonce is on a distinguished road
droveavolvoonce's Avatar
1993 SC2
Hi.
I purchased the 'Master Set' of these bushings a while back, gradually putting them in when it makes sense to do so - and I am not using some of the bushings that came in the set( I have the RED ones).
Let me know which ones you are looking for specifically out of the set and I'll let you know if I'm using them.
For example - I just replaced my lower control arms in the front with MOOG. The arms came with rubber bushings in both ends and I decided to not bother putting in the poly bushings, so I have those up for grabs.
Best,
daVo
1995 SC2 Plum 4-Disc 5SPD $1495 2.17.10 (111K to present)
1993 SC2 Silver 4-Disc Auto $1500 8.2007 to 2.2010 (195K-ish JY R.I.P. 5/7/10)
droveavolvoonce is offline   Reply With Quote
Old 09-09-2011, 12:38 AM   #8
tacticalturkey
tacticalturkey is on a distinguished road
Location: Toward the North end of the Central Valley, CA
1999 SL1
Have run Energy Suspension bushings on my chevelle, old Nova and my old pickup. The Chevelle was rear control arm bushings, and I didn't lube them enough and they squeaked!
The nova was front control arm bushings with a little more lube: better and ALOT more firm, just from those(the old ones were pretty worn though)
The pickup: I put rear control arm bushings in and got smart, I drilled and tapped small holes in the outer metal sleeve to be able to apply more silicone grease, but can't find it in a grease gun tube! The are alot better too!
Want to put them on my SL1...
My $.02
tacticalturkey is offline   Reply With Quote
Old 09-09-2011, 10:45 AM   #9
Redhotftw!
My $.02
You should have installed Zerk fittings in the holes you drilled.
You could sub a lithium grease for the silicon.
It would have been cake to squirt lithium in there through the fittings.
1998 "Red Hot" Sc2
Old 09-09-2011, 10:58 AM   #10
DIYguy
DIYguy's Avatar
1997 SC2
Wrench Re: energy suspension bushings
I have them on the SC2's front stabilizer bar mounts to the subframe. The original rubber ones were mushed out and so I thought I'd use the ES bushings (with lube fittings ) as replacements.
Wow, big difference. Worth every penny. Of course the old ones were shot, so anything probably would have made a difference. No squeaks because I lube them at every oil change (synthetic grease only).
On the other hand, on my last truck (K1500 Chevy) I replaced every piece of rubber in the suspension, front and rear, with ES parts. It handled better but there was no practical way to lube most of the bushings, such as on the rear leaf spring shackles. So eventually they started squeaking, especially when the weather was cold and humid. Not so pleasant.
Personally, I would not replace everything in the SC2's suspension with ES parts, just the sway bar mounts (I'll do the rear bar mounts one of these days, and then only with ones equipped with lube fittings).
Just my $0.02 as well. Others I know absolutely swear by them and would install them on their kitchen blenders if ES made something for that purpose.
DIYguy
Quando Omni Flunkus Moritati
97SC2 Saturn (gone but never forgotten), Gen6 Camaro, Cruze Eco, Chevy SS P/U, Honda VT1100C, Honda CBX
Old 09-09-2011, 07:47 PM   #11
cwl5005
cwl5005's Avatar
2004 VUE Red Line
Thank you for all the input.
Old 09-10-2011, 12:02 PM   #12
tacticalturkey
1999 SL1
@ Redhotftw!
I did put zerks in, but still couldn't find the grease, which I believe is dielectric grease. I did get one of those little refillable grease guns with the thumb pump for my chainsaw and impact gun. I'll probably get another one and put the silicone paste in it for the bushings I have yet to buy or install.
Old 09-10-2011, 12:11 PM   #13
G.M.
G.M. is on a distinguished road
G.M.'s Avatar
if you get the black bushings, they are graphite impregnated. That means, you won't need to lube them, and are a lot less likely to squeak.
I've had mine in for 3 or 4 years now. I had a set come apart on the LCA's, so I also replaced the LCA's with regular rubber, and kept the poly in the rest of the car.
As for feeling a difference...no, not really. But my rubber components weren't blown out yet.
turbo saturn - 400 club
www.sixthsphere.com
http://www.cardomain.com/ride/3895969/1998-saturn-s-series-sl2-sedan-4d
G.M. is offline   Reply With Quote
Energy Suspension Bushings on sway bars s-seriesguy S-Series Mods 1 02-24-2008 01:38 AM
anyone used energy suspension bushings 94503 S-Series Mods 7 08-13-2007 04:27 PM
energy suspension sway bar bushings zzyx7 S-Series Mods 1 02-06-2007 12:28 AM
Source for Energy Suspension Bushings? Bluesideup S-Series General 3 03-22-2006 12:01 AM
Energy Suspension bushings pbrown Mods and Performance 0 07-03-2002 01:34 AM
