Old 11-26-2010, 03:50 AM   #1
mwayne5
mwayne5 is on a distinguished road
1997 SC1
Default Marvel Mystery Oil users...
Hey, I was reading up on MMO and I'm thinking of adding it to my car (Auto '97 SC1). How do I go about adding it? Should I add it a few hundred miles before my next oil change, or can I add it whenever? Also, how much do you guys put in when you add it?
Thanks
1997 SC1 Autotragic. Donated with 116,175 miles, bought with 68,000 miles.
Black w/ gold flake.
The basics:
http://www.saturnfans.com/forums/showthread.php?t=163654
mwayne5 is offline   Reply With Quote
Old 11-26-2010, 08:17 AM   #2
droveavolvoonce
droveavolvoonce is on a distinguished road
droveavolvoonce's Avatar
1993 SC2
Default Re: Marvel Mystery Oil users...
When I've used MMO so far, I've either added a full quart at oil-change-time or added it as-needed to top off the system instead of my usual 5W30 (knowing that my car consumes oil at ~1100 mi per quart, I'll go through the full quart of MMO long before the next change.
Will try doing an MMO soak at some point. Probably in the spring.
Best,
daVo
1995 SC2 Plum 4-Disc 5SPD $1495 2.17.10 (111K to present)
1993 SC2 Silver 4-Disc Auto $1500 8.2007 to 2.2010 (195K-ish JY R.I.P. 5/7/10)
droveavolvoonce is offline   Reply With Quote
Old 11-26-2010, 10:20 AM   #3
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2000 SW2
Here're the instructions for the pistol soak that DAVO mentioned above:
http://www.saturnfans.com/forums/showthread.php?t=80118
Also like DAVO said, I will sometimes top off my oil with MMO a couple hundred miles before my next oil change. I think the official amount you can add is up to 20% of total oil capacity. You can also add MMO to your fuel at I think 4oz per 10 gallons, but check the bottle.
ShawnV is offline   Reply With Quote
Old 11-26-2010, 12:01 PM   #4
In addition to that thread ^ ^ ^ read this one:
http://www.saturnfans.com/forums/sho...urn+head+clean
I just searched for the procedure for the piston soak the other day, doing my second one. The first thread has great pictures, but does not (that I could remember) mention turning the engine so that the pistons are roughly midway in their travel.
Not sure if either thread mentions it, but someone recommended (after pulling the PCM-B fuse) adding the MMO to a warm engine, and taking the engine through at least one full rotation with MMO in the cylinders, before setting it to the mid point.
Old 11-26-2010, 05:38 PM   #5
mwayne5
1997 SC1
=\ I wish I could do this. Mechanical work at my apartment complex is considered a lease violation with a pretty nice fine attached if I get caught and oil changes aren't that easy to hide. I may be able to get away with adding the MMO to the spark plug wells and the crankcase since it isn't as messy or as noticeable as an oil change. I could also change my spark plugs at this time too.
If I go ahead and do this, would it be safe to drive the 3 or so miles to the shop after the piston soak to get the oil changed with all that gunk floating around?
The basics:
Old 11-26-2010, 09:17 PM   #6
ShawnV
ShawnV's Avatar
2000 SW2
It should be all right. Make sure you spin the engine over to ensure the MMO is out of the cylinders before you reinstall your plugs. Remember that fluid between the piston and plug will not compress...
Marvel Mystery Oil- yea or nay MikeNW S-Series General 2 04-14-2008 03:36 PM
Marvel Mystery Oil SATURNER S-Series General 8 05-23-2005 10:50 PM
Marvel Mystery Oil in SW2 ScottSaturn83 S-Series Tech 21 10-08-2004 04:12 PM
Marvel Mystery Oil bbarbulo S-Series Tech 29 07-13-2003 05:47 PM
Mystery Marvel Oil, is it worth using? Mark G S-Series Tech 16 08-21-2002 04:15 PM
