Old 12-12-2019, 05:33 PM   #1
DawnR
DawnR is just really niceDawnR is just really niceDawnR is just really niceDawnR is just really nice
DawnR's Avatar
Default 97 SW2 Manual RPM's rev up while Hwy driving in 5th gear.
Hey everyone!
Long time no chat.
My 97' SW2 currently has 227k miles. I am still so in love with my little car.
The speed limit in WI ranges from 55-75mph on various freeways. The past 6 months or so while I am in 5th gear. The RPM's will suddenly jump. This is at random, I cannot find a common factor or driving habit that I can figure.
Cruise on/off. Uphill/level? Passing/not passing.
Does anyone have any ideas what is happening and what I should start looking into.
There are no check engine lights illuminated and no pending codes. I also had my transmission fluid changed about 25 thousand miles ago.
Thank you
I read, I learn, I try!
DawnR is offline   Reply With Quote
Old 12-12-2019, 09:29 PM   #2
Default Re: 97 SW2 Manual RPM's rev up while Hwy driving in 5th gear.
That is often symptom that the clutch is slipping under full engine load.
The next time you are cruising in 5th, at about 3000 rpm and on flat ground, punch the accel pedal quickly to the floor and hold it there. If the rpm increases beyond what you would expect from the car accel, then the clutch is probably getting tired.
This kind of problem usually first shows up when you shift to 5th on an uphill. If you are careful with the shifts, the clutch can last many years more. However, if it is happening with just you or the CC doing gentle non-shift throttle changes, then I think you are likely to need a clutch soon.
I suppose there is also a possibility that the clutch slave-cylinder is getting stuck so that it can't retract enough, but that is very unlikely. And, I don't think the "wire test" will be meaningful.
Old 12-13-2019, 03:24 PM   #3
DawnR
DawnR's Avatar
Thank you Billr
Can a clutch be done by a DIY'er like me?
I have been very comfortable mechanically with various cars.
Old 12-13-2019, 05:33 PM   #4
It's doable - fairly well documented. Not sure if a video ever got made, but there are a lot of links with tips in this thread
http://www.saturnfans.com/forums/sho...d.php?t=236009
Old 12-13-2019, 06:37 PM   #5
I'm about to do it. As always I'll document the process.
Old 12-14-2019, 10:15 AM   #6
RobertGary1
1996 SC2
I felt like this car was one of the easiest clutches to change. Transmission doesn’t need to come out; just slide into back.
-Robert
Old 12-15-2019, 02:23 PM   #7
DawnR
DawnR's Avatar
AWESOME! That would be so helpful
Thanks...I am not driving much this winter so I very much look forward to your process.
Tips on Driving a Saturn 95 SW2 Manual DOHC? Seifer8 S-Series General 9 05-16-2012 11:57 AM
Manual transaxle pops out of gear while driving. Saturn4life S-Series General 5 09-16-2010 12:28 AM
Driving Saab 9-3 1.9 TDI with 6-speed manual AuraXRFan Aura General 79 03-07-2008 10:43 AM
shifter feels grindy? popped out of gear while driving spiffious S-Series Tech 13 11-10-2006 04:11 PM
Detroit Driving Report: FWD 5 Speed Manual PCF Vue General 15 03-19-2005 09:21 PM
