Old 06-20-2009, 12:09 PM   #1
ralfie
ralfie is on a distinguished road
Default AC - 95 SL2 Not functioning
I have a 95 SL2, that has been running great. The AC just quit running, had it serviced last summer and it ran fine.
This spring I turned it on and no cold air.
Checked the fuses, and even rotated the relays (all 3 the same on this model) no change. I jumped the clutch from the battry and it ran...I'm thinking the only thing left is a short in the wire someplace and I'm not looking forward to tracing the wire bundle and taking the front end apart...anyone have this problem and got it resolved?
ralfie is offline   Reply With Quote
Old 06-20-2009, 12:24 PM   #2
Default Re: AC - 95 SL2 Not functioning
Originally Posted by ralfie View Post
I have a 95 SL2...the AC just quit running, had it serviced last summer and it ran fine. This spring I turned it on and no cold air....
No need to check any wiring issue as you're looking in all the wrong places. You have a LEAK that won't get fixed by annual recharges. Find the source of the leak and decide if you can do the mechanical repairs and/or leave this to a pro. To fond the source of the leak; http://www.saturnfans.com/forums/showthread.php?t=80107
Old 06-23-2009, 11:38 AM   #3
ralfie
Hey thanks bro, I looked in the Haynes manual and it suggested that it was more than just a wiring problem, but I got tired of troubleshooting...
Old 06-23-2009, 12:51 PM   #4
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
Yes as fdryer said you most likely have a leak. The compressor has a built in safety switch that will not allow the A/C clutch to engage if it detects too low a pressure otherwise the compressor could be damaged.
Col.FUBAR is offline   Reply With Quote
speedo not functioning molbly S-Series Tech 9 06-18-2008 09:44 PM
OnStar Not Functioning Bluealien Aura General 9 04-01-2008 01:43 PM
Odometer/ Tripometer not functioning leskiss S-Series Tech 1 11-27-2005 08:29 PM
instrument panel non functioning brotherhay S-Series General 6 10-30-2003 03:02 AM
instrument panel non functioning brotherhay S-Series Tech 2 10-25-2003 09:19 PM
