Old 06-15-2008, 04:52 PM   #1
molbly
molbly is on a distinguished road
Default speedo not functioning
didnt find anything in the search that seemed to matched but my speedo isnt working just curious about possible problems before i go tearing into it and mess up something else thanks for any help
molbly is offline   Reply With Quote
Old 06-15-2008, 08:23 PM   #2
stang50
stang50 is on a distinguished road
stang50's Avatar
1997 SL1
Default Re: speedo not functioning
Could be the cluster or the VSS. How long has this been happening and has any recent repairs been done on your vehicle? Is the odometer working properly?
stang50 is offline   Reply With Quote
Old 06-15-2008, 10:45 PM   #3
molbly
just bought it a month ago but the fronts brakes were shot so today is the first day ive driven it and no i drove 20 miles and the odometer didnt move and where is the vss located at
i didnt pay attention to the cluster when i looked at buying it so i dont know how long this has been going on
Old 06-16-2008, 12:02 AM   #4
stang50
stang50's Avatar
1997 SL1
The VSS is the vehicle speed sensor. Its located on the back of the transmission and shoud have a plug and wires attached to it...
Old 06-16-2008, 09:06 PM   #5
virnin
virnin is on a distinguished road
virnin's Avatar
Ok, now you've listed two separate but potentially related problems. Are you saying that BOTH the Speedometer AND the odometer(s) are not working? They both use the signal from the VSS. The VSS is on the firewall side of the transmission, right below the throttle body and EGR valve.
virnin is offline   Reply With Quote
Old 06-16-2008, 09:18 PM   #6
molbly
is there a way to bench test the vss or would i be better off just putting a new one on since it is so old anyway and yes my speedometer wont move and my odometer along with the trip gauge dont move
Old 06-18-2008, 08:24 AM   #7
stang50
stang50's Avatar
1997 SL1
Here is a picture of it from under the vehicle it's easier to see from underneath....
Old 06-18-2008, 12:05 PM   #8
Drive to where you can coast safely, accelerate to, say, 20 MPH, push in the clutch and floor the accelerator. If the RPMs won't go past about 4000-4500, the VSS isn't working, or at least, it's not sending a signal to the PCM.
Old 06-18-2008, 07:24 PM   #9
molbly
thanks for the help i found the sensor and one of the wires was cut so a little strip a little twist and a little tape and i now have a speedometer and mileage which makes me wonder how long it had been going on with the previous owner and they didnt disclose that so it could have a lot more miles on it is suppose
Old 06-18-2008, 09:44 PM   #10
stang50
stang50's Avatar
1997 SL1
That's true, mine was disconnected for 2 years and the previous owner made trips from al to nc frequently. It shows 260k but i bet its got over 300k on it...but glad you got it going..
AC - 95 SL2 Not functioning ralfie S-Series Tech 3 06-23-2009 12:51 PM
OnStar Not Functioning Bluealien Aura General 9 04-01-2008 01:43 PM
Odometer/ Tripometer not functioning leskiss S-Series Tech 1 11-27-2005 08:29 PM
Search Function still not functioning trooper2man Vue General 3 09-08-2004 06:07 PM
instrument panel non functioning brotherhay S-Series Tech 2 10-25-2003 09:19 PM
