Old 03-15-2019, 01:47 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default Paint on valve cover
1997 SL SOHC
What is the coating on the valve cover? Clearcoat? It is peeling down to metal in a few spots, I'd like to wire brush the spots and rattle-can spray it silver.
Do you think Rust-Oleum would stick? Or do I need some high temperature paint?
08 Burgman 400
Add to MikeNW's Reputation
Rate the quality of this post and help MikeNW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-15-2019, 04:34 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Paint on valve cover
High-Temp is the only stuff that won't burn off fast.
Old 03-15-2019, 04:41 PM   #3
Waiex191
Waiex191's Avatar
The valve cover does not get very hot. I bet rustoleum would be fine.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 03-15-2019, 06:39 PM   #4
Originally Posted by MikeNW View Post
1997 SL SOHC
Yep, should work or pick up a can of engine silver. Do not use high temp as you can not properly bake it as required.
Old 03-15-2019, 08:43 PM   #5
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Dupli Color Engine Paint
https://duplicolor.com/product/engin...l-with-ceramic
RockAuto
https://www.rockauto.com/en/parts/du...ne+paint,52523
NGK BKR6E-11 spark plugs
Old 03-15-2019, 10:50 PM   #6
Macgyver
Usually I'll spend the extra time powder coating the valve cover if I rebuild the engine. If you have the option available, it lasts around 10 years.
Add to Macgyver's Reputation
Rate the quality of this post and help Macgyver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-16-2019, 06:03 AM   #7
toggenburg
toggenburg's Avatar
As Mattwithcats showed,
It's a high temp (500 degree F) paint, not Rust oleum stuff
Old 03-16-2019, 07:42 AM   #8
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
1997 SC2
Any high temp engine paint (available in any auto parts store) will work fine. I'd just give it a good cleaning, then sand or wire brush any loose paint until you've got a smooth surface. Wipe down with solvent to dissolve any remaining grease/oil/wax and paint 'er up.
Best,
All governments suffer a recurring problem: Power attracts pathological personalities. It is not that power corrupts, but that it is magnetic to the corruptible. -Frank Herbert-
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 03-16-2019, 08:50 PM   #9
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
I wanted to paint my new used aluminum valve cover but got lazy and time is not my pal so I left it. I looked at all the deep recesses around the word Saturn and got scared off. I think sand or glass blasting it would’ve been the best. (Next time)
• 1994 SL1 new traded
Add to dummo's Reputation
Rate the quality of this post and help dummo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-17-2019, 03:55 PM   #10
timl865
timl865 has a spectacular aura abouttiml865 has a spectacular aura abouttiml865 has a spectacular aura about
I stripped mine and used high heat engine paint. Looks great!
File Type: jpg Screenshot_20190105-083910_Gallery.jpg (185.6 KB, 21 views)
Add to timl865's Reputation
Rate the quality of this post and help timl865 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timl865 is offline   Reply With Quote
Old 03-18-2019, 01:01 PM   #11
MikeNW
MikeNW's Avatar
1997 SL
I wire brushed it, and degreased it, ready to shoot Duplicolor as soon as the garage attic is >75 degrees
Yes those photos above look good!
08 Burgman 400
Old 03-19-2019, 08:15 AM   #12
VUEmaniac
1997 SC2
Yep, that does look good. When I did mine, I got a small 3" paint roller from HomeDepot and lightly rolled on black paint on the letters without getting any drips on the sides to give the letters some contrast. Very low nap roller and very light touch over maybe 2-3 coats. After it dried, I shot the entire cover with two coats of high temp clear.
Best,
Paint aluminum valve cover Mark121 S-Series Mods 11 06-03-2015 09:40 AM
What problems can be diagnosed / fixed under the valve cover / timing cover? Dalamar S-Series Tech 1 09-15-2011 09:42 AM
How Do I paint the Valve Cover? myolbug S-Series Mods 11 01-27-2009 09:14 PM
Replacing composite/polymer valve cover with aluminum cover DOHC idaw8184 S-Series Tech 0 08-04-2008 01:31 PM
FS: Valve Cover Gasket for BLACK Plastic Cam Cover, S Series jmettee Classifieds 0 11-02-2003 11:48 PM
