Old 03-14-2019, 06:51 PM   #1
timl865
timl865 has a spectacular aura abouttiml865 has a spectacular aura abouttiml865 has a spectacular aura about
Default Proper way to do compression test?
I just bought the harbor freight compression tester and need to know the right way to check compression. I have never done it before and have the dreaded cyl 3 misfire. Thanks!
Add to timl865's Reputation
Rate the quality of this post and help timl865 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timl865 is offline   Reply With Quote
Old 03-14-2019, 06:53 PM   #2
Default Re: Proper way to do compression test?
To prevent washing the cylinders down with fuel remove the PCM B fuse to shut off the fuel pump, injectors, and ignition before starting the test. Remove all spark plugs and block the throttle open. Use a low charge rate battery charger to fully charge the battery before conducting the test.
Crank the engine until the gauge quits increasing and compare both the final pressure and number of compression strokes to reach the max pressure, cylinder to cylinder. You can do this test either cold or hot or warm just mention it when stating results.
For example if you find all cylinders produce a final reading of 200psi but the compression cycles are as follows: 1-8, 2-6, 3-8, 4-14 then it should be obvious that cylinder #4 has a serious problem with leakage past either the valves or compression rings.
FSM states the MINIMUM number of compression cycles is 10 and a Fully charged battery is required to obtain the full 250RPM cranking speed.
Nominal compression for a high mileage good condition DOHC is 190-220psi and SOHC is 175-205psi.
Do not screw it into the head past the point the sealing o-ring just contacts the head. Do not overtighten as it will leak.
Old 03-14-2019, 06:59 PM   #3
timl865
Perfect! Thank you!
Old 03-15-2019, 08:10 AM   #4
onlinebiker
Facing west whilst slaughtering a goat is always helpful too....
Ya just can't be too thorough...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 03-15-2019, 09:22 AM   #5
youstolemybeer
youstolemybeer is on a distinguished road
2001 SW2
thats only if your west of St Louis. Otherwise for proper compression test its facing North while slaughtering goats
Add to youstolemybeer's Reputation
Rate the quality of this post and help youstolemybeer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youstolemybeer is offline   Reply With Quote
Old 03-15-2019, 11:52 AM   #6
Silverblu02SL2
Would removing the PCM B fuse and then crank the engine result in a DTC?
Add to Silverblu02SL2's Reputation
Rate the quality of this post and help Silverblu02SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-15-2019, 12:58 PM   #7
No - the PCM gets no power, so can't set a code
Pulled the PCM-B lots of times, never caused a code. Pulling the PCM-B will actually clear any stored codes.
Old 03-15-2019, 02:18 PM   #8
Silverblu02SL2
Sorry, the question I actually meant to ask was: Will it set all readiness to "Incomplete"
Old 03-15-2019, 02:33 PM   #9
I believe it will - loses all memory of completing the readiness tests, so will set it back to "Incomplete", default fuel maps, default shift points for the auto trans, etc.
Don't have emissions testing here, so not something I ever thought about. Plus my normal commute cycle completes the tests pretty quickly, the times I checked with a reader
Old 03-15-2019, 03:30 PM   #10
YES IT WILL. You can attempt to disable fuel and spark independently of just pulling the PCM B fuse or you could try just pulling the PCM I as it should accomplish the same thing. Or you can move on down the tree of increasing potential mechanical damage and start pulling relays and random fuses.
Proper engine compression after lost oil? luvme2tymes S-Series Tech 14 08-21-2009 08:42 PM
What is the proper way to do a fuel pressure test? groingo S-Series General 3 07-09-2009 12:20 PM
compression test sluketic S-Series Tech 3 07-07-2008 08:22 PM
Compression test junker S-Series Tech 3 02-21-2008 08:03 AM
Detecting proper seating of new rings by compression check? roswell998 S-Series Tech 4 10-29-2004 01:27 AM
